G.E.M. Module
Old Oct 27, 2006 | 02:11 PM
Double Trouble's Avatar
Double Trouble
G.E.M. Module
I know that this subject has had to have been covered before but I cant find the info that I am looking for anywhere.
Here is my story:
I own a 1999 Ford Expedition Eddie Bauer 5.4 liter.
We started have trouble with the A/C blower cycling on & off on its own (even without the key in).
Took it in to the dealer, they replaced the fuse box under the driverside dash due to water leaking in thru the windshield.
Drove the truck about a week now all my warning lights (low fuel, oil light, brake light, low range light & the over head console readout) are coming on and off as we drive.
Could this be the G.E.M. Module or has someone else found another fix.
Thanks in advance for the help that you can throw my way.
Old Oct 27, 2006 | 09:20 PM
FTE Herman's Avatar
FTE Herman
The symptoms you describe are indicative of a soaked GEM. Is the water leak corrected? If so and the problem doesn't stop of it dries out, it is probably time to replace the GEM. What I don't recall is if you can replace it with a junker one or if it is somehow 'keyed' to the vehicle/PCM.
Old Oct 29, 2006 | 10:35 PM
Tptoe's Avatar
Tptoe
What hkiefus says:
Make sure the leak is fixed !
I went through 2 GEMs.
Sooo ...
I had to replace windshield. It fit poorly because it was warped.
Have them check for leaks by running a hose over the windshield and seals for at least a half hour.
Then I had the GEM and fuse holder replaced.
That finially killed the ghost in the machine.
fstfwrd
Feb 4, 2025 04:03 PM
Rusty Axlerod
Nov 5, 2015 04:29 PM
jmmranger
Oct 28, 2011 09:42 PM
Babcore
Dec 22, 2002 06:44 PM
Legend
May 23, 2002 01:51 PM
