Engine Swap
Old Oct 26, 2006 | 07:05 PM
eric.roberson's Avatar
eric.roberson
Engine Swap
I'm trying to put a 302 TB in a 1960 F100, what all will i need and where can i find it?
Old Oct 26, 2006 | 09:27 PM
Dustin1690's Avatar
Dustin1690
Whats the original engine in the truck im sure you will need correct engine mounts radiator right transmission that will bolt up to the 302 and a place where you could find this stuff is a junkyard
Old Oct 27, 2006 | 06:12 AM
eric.roberson
Smile Engine Swap
Thanks, coming out is a 223 i believe or at least that is what i was told it is. Do you suggest going carb or leaving it as is?
Old Oct 27, 2006 | 09:37 AM
jowilker's Avatar
jowilker
Eric, I must disagree with Dustin. If it were 65 or newer he would be correct. The pre 65 trucks used a front mount rather than a side mount system.
The best thing depending on your skill level might be to purchase a side mount kit from one of the aftermarket guys like Carpenter, Rick Allen, LMC, etc. Then you can install the side mount engine in.
John
Old Oct 27, 2006 | 10:00 AM
eric.roberson
Smile engine swap
yes, it is front engine mounted 223, thanks for the info, would you go carb or try a standalone modification EFI system?
Old Oct 27, 2006 | 10:42 AM
jowilker's Avatar
jowilker
Eric, The skill level required to install an EFI system is much greater than a carb. We have no idea of what that may be, how many tools or shop space you have access to. It is not an easy retrofit.
John
Old Oct 27, 2006 | 04:51 PM
eric.roberson
Smile engine swap
I have access to an assortment of tools, but just listening to you all i think i will just change it to carb and go from there.
Thanks all
Old Oct 28, 2006 | 01:23 AM
Dustin1690's Avatar
Dustin1690
Thanks all
Well thats probably the easiest road to take for sure unless you really want fuel injection up to you...
Old Oct 28, 2006 | 01:57 PM
magee's Avatar
magee
Personally, I prefer a carb. But, I like to tell my vehicle what to do instead of letting a computer do it. EFI just has too many things that can go wrong and a simple problem ends up taking several days just to diagnose. Especially if it's a retrofit. Of course, that's just my opinion.
Old Oct 29, 2006 | 11:23 AM
SCWIDVICIOUS's Avatar
SCWIDVICIOUS
I am in the same boat with you on that. The idea of FI is appealing, but carbs are just fine, and very tunable in any application.
If you know what your doing with a carb, your truck can be like mine, I dont have to hit the gas in the morning, I dont have to pull the choke, and I dont have to force it to run in the mornings no matter how cold it is. It runs like an FI, but its a carb
Old Oct 29, 2006 | 12:06 PM
eric.roberson
engine swap
Rick,
Send me some pointers on how to make that carb run like FI. I can use that on my other carbed vehicles.
Thanks
Eric
Old Oct 29, 2006 | 01:18 PM
SCWIDVICIOUS
what type of carb are you planning on running on it?
holley, edel, motosport, carter, etc? 1, 2, 4 barrel
What type of intake? high rise, low, dual plane, victor, airgap, w/wo egr etc...
What type/size cam (roller/flat; rv/truck/car/hotrod; lobe seperation)
IS the engine stock, modded, built, .... how many miles, does it have any blowby,
Type of ignition will you have, electronic, points, crank triggger?
What will the truck be used for, pulling, racing, normal driving?
What kind of gearing does it have? high low middle of the road....
tpye of transmission auto, straight....
all of these and a bunch of others can be factors in setting them up..
the more info you can give me, the better i can help you out.
Even things like what kind of breather will it have?
Spark plugs.
from there I can perhaps give you tips on how to get it close...then fine tuning should get you purring like a kitten.
I know it sounds like a lot of info, but really once its done, then thats pretty much it, except a possible fine tuning once in a while.
Rick
Old Oct 29, 2006 | 01:37 PM
eric.roberson
that will take a few, but i will get back with you
Old Oct 29, 2006 | 02:28 PM
SCWIDVICIOUS
ok...no problem
