fuel filter light
Old Oct 26, 2006 | 01:30 PM
why165's Avatar
why165
fuel filter light
what does the fuel filter light supposed to mean??
Old Oct 26, 2006 | 01:43 PM
trooperkelly's Avatar
trooperkelly
Not enough fuel coming out of the filter, could mean clogged filter or bad fuel pump as was the case when mine came on
Old Oct 26, 2006 | 05:56 PM
why165's Avatar
why165
how many pumps on a 92. lift injection and what else it has only done it on one tank( the rear one)
Old Oct 26, 2006 | 09:55 PM
PLC7.3's Avatar
PLC7.3
The light indicates a vacuum in the filter header, as stated no fuel flow, plugged filter or bad lift pump. Since it is rellevant to one tank only I would check the FSValve for operation. When switched the valve should ziip back and forth, when switched it will change the fuel gage/tank fuel level to the one selected.
Old Oct 27, 2006 | 03:03 PM
why165's Avatar
why165
were would that little valve be located.
Old Oct 27, 2006 | 05:45 PM
PLC7.3's Avatar
PLC7.3
Under the drivers side on the frame..........
