PCV Valve
Old Oct 27, 2006 | 02:44 PM
pbear6969's Avatar
pbear6969
On mine I have a Ford Racing breather cap and on the other side I have a K&N filter breather cap. My carb didn't have a connection for a pcv valve so I went that route.
Old Jan 7, 2025 | 10:14 AM
AppalachianSurvivor's Avatar
AppalachianSurvivor
Originally Posted by 76supercab2
Do you have a picture of this?
The PCV valve should be on the hose connected to the vacuum meter the crankcase vapor to the intake.
The PCV system on my 390 is
PCV valve in passenger valve cover next to firewall
Hose from valve to back base of carb
Oil fill cap on driver side valve cover with hose to air filter mounted in air cleaner assebly.
Putting the valve on the intake side of the system will not allow the system to function properly.
An excellent answer to a question I posed on another forum. The information you supplied matches exactly what I was told and finally, with that knowledge, found on my '74 F100 with a 360.
A.S.
eallanboggs
2004 - 2008 F150
Dec 20, 2021 06:09 PM
seaagg05
1997 - 2003 F150
Jan 26, 2014 12:05 PM
jlom
Jan 7, 2014 04:35 PM
KingRanchMan02
1997 - 2003 F150
Jun 7, 2008 09:17 PM
mtfl1
Nov 14, 2001 09:04 AM
