Best Gauges
Old Oct 25, 2006 | 08:45 PM
a-rod's Avatar
a-rod
Best Gauges
Ok, Ive decided I better get a set of A-pillar gauges for my truck so I can actually see what my powertrain is doing. Ive seen some that actually have a temp gauge for the rearend? but not sure if that is really necessary since I dont tow all that often, and im not in a very hot climate. Theres alot out there, what do you guys suggest?
Old Oct 25, 2006 | 08:59 PM
blackhat620's Avatar
blackhat620
a-rod,
Isspro or Autometer are two popular brands. I am partial to Isspro but Autometers work just fine also.
As far as what gauges, boost, egt, trans temp and for a fourth voltage.
Hope this helps
Old Oct 25, 2006 | 09:25 PM
a-rod's Avatar
a-rod
also, I recently saw a 6.0 with a digital fuel pressure reading inside the cab? Is that guy crazy, or is that something worth looking into. First time ive seen that.
Old Oct 25, 2006 | 09:33 PM
blackhat620
a-rod,
Some of the tuner displays can show several different engine parameters. Unless you are running a heavily modified truck, more than just a basic tuner and exhaust, fuel pressure reading are of little to know use to you. That is unless you just like a lot of information to track for your own knowledge.
The most important gauges are the ones i listed. Even with a stock truck. When any of these parametes change quickly from the norm it will alert you to problems developing and you can immediately take corrective action.
Hope this helps
Old Oct 25, 2006 | 09:41 PM
a-rod's Avatar
a-rod
Thanks blackhat620
Old Oct 25, 2006 | 10:29 PM
tex25025's Avatar
tex25025
If your going to spend the money for four gauges, unless you just like the look of analog gauges(which I can understand), I would go for a solid digital gauge. You'll actually be able to monitor those 4 parameters as well as others and you can even have a gauge that adjusts speedo for an aftermarket tire size, if your inclined to do that. If your running a tuner, most digital ones will work for other brands then just their own. The monitor might support functions that the tuner can't do, but most of them will perform what your tuner is able to do. Most tuners allow for egt backdown at certain temps and same thing for tranny temps as well, but you can't do that with regular analog gauges. It's preferance, but if your planning on doing 3-4 gauges, then I would think about looking at digital ones, for the reasons I stated about the backdown safety features and to me, digital ones are more accurate, you know that your egt is 1227 degrees, instead of an analog one where your guessing where your at.
Old Oct 26, 2006 | 10:10 AM
manofstihl660's Avatar
manofstihl660
i was just gonna get the dual a pillar set up from auto meter with exaust temp and boost pressure, jegs has them for 225 $ i think
Old Oct 26, 2006 | 08:17 PM
gregk's Avatar
gregk
Thumbs up Best gauges
I just installed a quad A pillar, in my 2006 F350 with autometer gauges and so far, I like them a lot. I installed egt, trans, boost and water temp. I am looking for lamp sleeves so I can change the white light, when the dash lights are on, to green to match the dash illuminated light. Hopefully, this helps. My .02 cents.
Old Oct 26, 2006 | 09:35 PM
Bear Hunter's Avatar
Bear Hunter
Check out Autometer's Ultra-Lite II's..... Awesome
Boost, Pyro, Trans ... at a minimum if you want to monitor engine parameters.
Old Oct 26, 2006 | 10:10 PM
4mil's Avatar
4mil
Has anyone used the "QUADZILLA COMMANDER" for monitoring purpose only. It is not a tuner as stand alone, only gauges.
Old Oct 26, 2006 | 10:47 PM
Bear Hunter
Here are what the Ultra-Lite II's look like at night... the gauge face is sliver during the day
Also shown is the Autometer DPIC (Dynamic Performance Information Center)
The DPIC measures the following:
1. Real Time G-Forces
2. 0-60 time
3. 60-0 brake time
4. 1/4 ET and speed
5. Reaction time
6. Rear wheel Horsepower
Old Oct 27, 2006 | 06:25 PM
Outdoors1's Avatar
Outdoors1
As to the fuel pressure guage, the diesel tech at the dealership I go to says that fuel pressure is good to have because a drop in fuel pressure indicates that your fuel filter is getting clogged, and low fuel pressure can damage your injectors.
Old Oct 27, 2006 | 07:11 PM
6L PWR's Avatar
6L PWR
I have a FASS 150/150 Fuel Filter and pump on mine to help the stock pump keep up with the mods. I have a fuel pressure gauge attached to it so that I know when to replace the filter in it.
Old Oct 27, 2006 | 07:31 PM
mjlevi's Avatar
mjlevi
I have the Isspro pillar gauges on mine...EGT, Turbo boost, Trans temp...however, I am thinking I may switch out the Turbo boost gauge for a Water temp gauge, as I feel it may be more important to monitor water temp, only because the Turbo boost gauge matches my factory Turbo psi gauge exactly, so why have it?!
Old Oct 28, 2006 | 05:02 PM
a-rod's Avatar
a-rod
So ill probly get a set of autometers, anyone know a good place to get them? Thanks for the replys.
