Fuel leak
Old Oct 25, 2006 | 08:00 PM
CC'sDad's Avatar
CC'sDad
Fuel leak
I seem to have a fuel leak. It is comming from the tube that drops down from the fuel filter bowl. Thought it might be a cloged filter causing a pressure build up so I changed the filter and it still leaks. Anybody have any ideas?
Thanks.
Old Oct 25, 2006 | 08:07 PM
PA_Ford_Man's Avatar
PA_Ford_Man
Here comes the new ULSD Fuel!
CC'sDad,
Is likely related to the new ULSD Fuel. Many people are now noticing this same problem. The new fuel is causing the O-Rings in the Drain Valve to leak. Many have suggested replacing them with Nitrile O-Rings.
Here's the most recent posting for this problem:
https://www.ford-trucks.com/forums/5...leak-help.html
Someone should keep track of how many people are having this problem. I bet it might beat the typical Glow Plug Relay problem that is seen this time of year.
