changing anti-freeze
Old Oct 25, 2006 | 01:31 PM
beemr's Avatar
beemr
What's the status for maintenance on changing the anti-freeze?
1) Time intervals/milage?
2) Type of fluid..i.e., specific brand, chemical composition, etc?
3) How about special fluids like Royal Purple or Evans NPG?
4) Warranty or performance issues?
Old Oct 25, 2006 | 01:41 PM
blackhat620's Avatar
blackhat620
1) Change interval as per owners manual.
2) Type fluid is one meeting Motorcraft spec as in manual (currently Ford Gold).
3) I don't know anything about the Royal Purple.
Evans is good stuff, a little spendy but has great benefits, and all who use it rave about it.
4) Need to change fluids at a minimum of proper intervals as outlined in the manual to maintain warranty coverage and proper performance.
Hope this helps
Old Oct 25, 2006 | 03:01 PM
beemr's Avatar
beemr
...so the Evans meets the Motorcraft Ford Gold specifications?
Old Oct 25, 2006 | 03:22 PM
blackhat620
beemr,
Here is a link to the evans site with more info.
www.evanscooling.com/index2.html
Evans is a superior product to ethylene glycol antifreeze, and was desigend for extreme applications. I am not sure if it carries any manufactures ratings as i did not see it listed on there site. I do know that GM worked with them early on to reduce cooling problems in the Corvette.
If you are the least bit hesitant about using Evans do to any possible warranty issues then i would say to stick with what the Manual lists.
Hope this helps
tbugher62
Nov 6, 2014 03:54 PM
DSMMH
Feb 21, 2008 12:04 PM
jopiel
Dec 28, 2007 01:55 PM
Trickedout420
15
Mar 16, 2007 06:39 AM
ford390gashog
Oil & Lubrication
Mar 20, 2005 06:56 AM
