Trans Indicator
Old Oct 25, 2006 | 04:26 AM
Chumbucket's Avatar
Chumbucket
Trans Indicator
How does the red pointer that show's drive,reverse ect on steering post get removed. (broke) It's 87 f250. C6
Old Oct 25, 2006 | 01:21 PM
Lazy K's Avatar
Lazy K
Replaced the one on my `87 F250 C6 diesel about 6 months ago. If you have the new replacement kit it explains a lot ( about $23.00 as I remember. ). You have to remove the surround fron the Inst. cluster and the cowling from round the lower part of the steering column just in front of the dash. Then remove the screws holding the inst cluster in. Ease the cluster forward and you get access to the two screws holding on the trans indicator. You can remove this without having the inst cluster fully removed. Getting the new one in is akward but doable. There is a sloted screw fixing at the other end of the cable that enables you to set the indicator pointer exactly right. Hope this helps.
Old Oct 25, 2006 | 03:10 PM
Chumbucket's Avatar
Chumbucket
Ok,Lazy thank's
Old Dec 20, 2006 | 10:37 AM
89MustangGX's Avatar
89MustangGX
I know this thread is old, but having trouble finding any info on this "kit" to fix the shift indicator. My cable is broken on mine -- will this fix it? Where do I get it?
Thanks!
Adam
Old Dec 20, 2006 | 10:53 AM
quicklook2's Avatar
quicklook2
ford dealer.
Old Dec 20, 2006 | 11:04 AM
89MustangGX
Originally Posted by quicklook2
ford dealer.
What does the kit consist of, and will it fix my broken cable problem? Also -- what is it officially called (so I know what to ask for).
Thanks!
Adam
Old Dec 20, 2006 | 01:36 PM
Lazy K's Avatar
Lazy K
In the kit you get a new "window" with the red pointer and with the new cable connected to it. Click on DirectFordParts in the list of sponsors and fill in the order page. I got one that way, about $23.00 if I remember right. Just ask for the tranmission shift indicator assembly.
Old Dec 20, 2006 | 02:48 PM
89MustangGX
Thanks -- I'll give it a shot. One final question -- is this the entire assembly, where I will have to specify what tranny gear pattern) I havem, or do I take apart mine once I get it and use this to fix it?
Adam
Old Dec 21, 2006 | 12:46 PM
Lazy K's Avatar
Lazy K
Other than the fixing screws you do not reuse anything from the old unit. Tell the parts guy you have a C6 trans. and if you have tilt steering and the new part comes ready to install.
Old Dec 21, 2006 | 01:02 PM
89MustangGX
That sounds great -- exactly what I'm looking for. I have an AOD in mine, but I assume they will have the part. Hopefully.
Thanks!
Adam
Old Dec 22, 2006 | 12:00 AM
89MustangGX
Ordered it today. Nobody wanted to give me a discount, had to pay list price of about $38 or so - OUCH - but it will be worth it.
Thanks again guys.
Adam
Old Dec 22, 2006 | 08:49 AM
89MustangGX
As a note to anyone searching.
I couldn't find the part in any of the online stores including diagrams, and that's why I ordered it from the dealer.
The part number for an AOD indicator is E7TZ7A110D and it can be bought for about $25 online. Live and learn...
I'll update this again once I install the part if I run into any snags, but looks pretty straightforward from this point on.
Adam
