93 4.0 Knocking under load.
I assume your using hi-test fuel to help cut down on the knocking, right?????
Actually premium fuel isn't recommended for this engine, as over time, it can cause excesive combustion chamber deposits, which will exacerbate the knocking problem under load.
With the vintage of this engine, a vacuum leak should be on your suspect list too.
Good suspect spots for vacuum leaks are, loose fitting, split, cracked, or missing vacuum lines & they could be located anywhere from the cabin AC/Heater control, to the PCV valve, to the brake booster, to the fuel evap canister, to intake manafold gasket leaks, from loosened fastners, which the 4.0L is famed for.
So a visual inspection of those lines & maybe a propane sniffer probe around the intake manafold, might be in order.
If you find a leak there, try retorquing the intake manafold fastners, pehaps if the gasket isn't sucked in it'll work.
On the carbon deposits, if you suspect the engine has this problem, you could try running most of your present tank of gas out, then filling up with a tank of Chevron or Chevron Texaco gas, with a bottle or Chevron Techron Plus, at the specified per gallon treat rate, then run most of that tank out, with some spirited highway driving, wih 3 mile runs at, or above 3K rpm, to loosen & remove the carbon from the combustion chamber.
I have to do this on a regular basis, to keep my 99 4.0L quiet, as it suffers from CCDI & it's very sensitive to ANY combustion chamber deposit build-up!!!!
If your 93 has a MAF sensor & you suspect the MAF sensor may be part of the problem, try disconnecting it & give her a run & see if the ping subsides. If so, suspect the MAF may be dirty, so remove it & carefully clean it with "throttle body" spray cleaner & look up stream to find out why it's dirty. Look carefully for a poorly fitting air filter, or improperly buttoned up air box.
If you have a MAP sensor instead of the MAF, try disconnecting it & do a test drive & see how it goes. If better without the MAP, then suspect it & replace it, as it can't be serviced.
Just some thoughts for consideration.
Let us know how it goes.
Do you have one of the vintage 4.0's? Cuz if ya do, the answer is here in this faltering forum for your review......
Do a search in THIS forum and look for...
*carbon build up
*vac leak (the lose bolt boogie)
*MAF sensor dirty, ESP if you have the kiddie/puberty driver and victim/childfest rated air filter that contamintaes it with oil. Namely, KY or the like.
*carbon build up
Yup the Seafoam sure will smoke things up for a while, sometimes scares the heck out of folks. They think they've blown a gasket or blown the engine. lol
After the decarb, is it running ok on regular now????
