ball joint removal?
Old Oct 23, 2006 | 03:25 PM
country17's Avatar
country17
ball joint removal?
what is the easiest way to change the lower ball joint
on a 1991 f150 4x4
any links and advice will be apprciated
and i know how to change them i just would like to know the easiest way to do so
thax
Old Oct 23, 2006 | 08:04 PM
Popa Tim's Avatar
Popa Tim
the easiest way... (remember you asked) ...take it to a shop.
There is no easy way. Sorry to break the news to you.
Old Oct 23, 2006 | 08:36 PM
country17's Avatar
country17
thax but i meant do it your self the easiest way
thax for the advice
Old Oct 23, 2006 | 08:39 PM
Josh88Ford's Avatar
Josh88Ford
might as well do the the upper ones too. And while you got the axle apart, you might as well replace the axle u joints, wheel bearings, seals...
do a search. you will find plenty of information on do-it-yourself info. Do it yourself. That way when it happens again, you know what to do, for cheap.
Haynes manual is always a must if you plan on working on the truck!
Old Oct 23, 2006 | 08:49 PM
Conanski's Avatar
Conanski
There is no easy way, this is a big job even with a heafty impact gun and a 20ton shop press!! A ball joint removal set will help as well.
Old Oct 23, 2006 | 11:25 PM
albung's Avatar
albung
i did mine in about two to three hours per side i didnt think it was hard to do at all but i have one piece hubs
Old Nov 2, 2006 | 09:00 PM
rdw516's Avatar
rdw516
Toolsource .com has a ball joint press kit for a little more than $100.00 It is designed to be used on dana 44 front axles. I have used it on multiple occasions and it worked great, also it can be used to press install and remove U-joints.
