scanner code help
Old Oct 29, 2006 | 03:53 PM
steveo420's Avatar
steveo420
scanner code help
I ran a scanner and got codes 35 and 42 Any help !!!
Old Oct 29, 2006 | 06:26 PM
xltlariat87's Avatar
xltlariat87
35-evp circuit above maximum voltage limit of 4.81 volts
42- hego sensor indicates rich condition (right side)
Old Oct 30, 2006 | 06:55 AM
steveo420's Avatar
steveo420
Thank you, how do I fix this problem?
Old Oct 30, 2006 | 07:38 AM
subford's Avatar
subford
What are you working on?
Year?
Engine size?
Model?
Transmission?
I take it this is not your 1977 F250.
Old Oct 30, 2006 | 07:47 PM
steveo420's Avatar
steveo420
Sorry its a 1988 F250 4x4 5.0 with a non ele. AOD
Old Oct 31, 2006 | 05:31 PM
steveo420's Avatar
steveo420
Any help? Thank you.
Old Nov 1, 2006 | 06:45 AM
subford's Avatar
subford
Service Code 35 indicates that the EGR Valve Position (EVP) sensor signal is greater than the Self-Test maximum value of 4.81 volts.
Possible causes:
Damaged EVP sensor.
Short to power in harness.
Open in SIG RTN.
Damaged processor.
* Key off.
* Disconnect EVP sensor.
* Rerun Key On Engine Off and Key On Engine Running Self-Test.
Is Code 31 present (ignore all other codes)?
Yes
GO to «DN6».
No
GO to «DN7».
Service Code 42 HEGO sensor right or rear, system indicates rich.
Possible Causes:
--Fuel injectors
--HEGO sensor
--Thermactor
--PCV
--Vacuum
--CANP
--MAP sensor
* Key off.
* Remove the PCV valve from the valve cover. Inspect both rocker cover hole and
PCV for damage, sludge build up, blockage and movement of valve plunger. Service as necessary.
* Run Engine Running Self Test.
NOTE:
For a No Start Go directly to «H2».
* Are any of the these codes present in KOER Self-Test, 41-91-42-92?
Yes
REINSTALL PCV valve. GO to «H2».
No
CHANGE engine oil and filter. REINSTALL PCV valve. DRIVE vehicle 5 miles/55mph. RERUN «Quick Test».
Old Nov 2, 2006 | 09:06 PM
steveo420's Avatar
steveo420
Thank you I will work on it this weekend!!!!
