No power
Old Oct 23, 2006 | 01:50 AM
GLAMIS's Avatar
GLAMIS
No power
Just got back from my trip. Wish I could say it was under my own power. Had to leave the trailer and get towed the last 60 miles. Climbing a hill and everything felt and sounded fine until I reached the top and leveled out. The boost started to drop and I was losing power fast when I got to the next off ramp I was only going 10 MPH then it just died. I let it cool down waiting for back up. After cooling for a while I Re started it and had enough to get off the freeway. After I got towed in I started it and almost seemed to run fine for a few seconds. I’m thinking head gasket. What can you guys tell me about this? I have a 2003 F-350 with a 6.0, exhaust, and an air cleaner.
Old Oct 23, 2006 | 09:40 AM
kw5413's Avatar
kw5413
Welcome to FTE and the 6.0 forum GLAMIS
Please take a few moments to read our site guidelines.
https://www.ford-trucks.com/guidelines.html
Hopefully, some of our resident Techs should be around soon to help
Sure wish our tech threads would return soon...
</WMFILTERED>
Old Oct 23, 2006 | 11:25 AM
BowTieHatr's Avatar
BowTieHatr
see if you can get the truck to no start again. when you do watch the oil pressure gauge. let us know what it does.
Old Oct 23, 2006 | 12:21 PM
GLAMIS's Avatar
GLAMIS
All the gauges looked fine & no engine lights ever came on. When i restarted it the first time the temp was a little higher than normal. What are you thinking the whole motor?
Old Oct 23, 2006 | 12:29 PM
vloney's Avatar
vloney
Nah-- theres been issues with the fitting on the high pressure oil pump blowing apart causing power loss when warm.Your oil pressure gauge will show if oil is available to the hpop to run the injectors.
Old Oct 23, 2006 | 12:43 PM
GLAMIS's Avatar
GLAMIS
More to the story ( maybe non-related ). Last week the truck was in the shop twice for water leaks. My thinking behind a blown head gasket was maybe compresion has been leaking into the coolant causing it to leak under the addeed presure.
Old Oct 23, 2006 | 05:06 PM
BowTieHatr's Avatar
BowTieHatr
did they put headgaskets on?
Old Oct 23, 2006 | 05:41 PM
GLAMIS's Avatar
GLAMIS
Dealer called and said two injectors. Running on 6 cylinder. 2 at the same time sounds strange.
Old Oct 23, 2006 | 05:51 PM
BowTieHatr's Avatar
BowTieHatr
we have a way to show bad and weak injectors. i glad they got you back on the road again.
Old Oct 23, 2006 | 05:53 PM
Gunner15a's Avatar
Gunner15a
This is VERY VERY interesting...........Beginning to sound a LOT like what happened to my truck after I took it in for an oil and fuel filters change.....
High pressure pump and #7 injector were out of commission.......
At least thats the word I have right now...........I have to wait till I get home to get the full scoop. My wife had the brains to have them photocopy all the mechanics notes when he was working on my truck..........
Reading along with GREAT, GREAT interest.......
Gunner15a
Old Oct 23, 2006 | 06:00 PM
BowTieHatr's Avatar
BowTieHatr
what year is your 6.0?
Old Oct 23, 2006 | 06:25 PM
Gunner15a's Avatar
Gunner15a
Mine? It's an 06 with 26K on the clock, give or take. Still under warrenty.
Gunner15a
Old Oct 23, 2006 | 06:29 PM
GLAMIS's Avatar
GLAMIS
Injectors #2 & #6 this time last time was #3 & #5 and the first time was #8. All in the last 8 months. Injector #4 is the only one left on this cylinder bank thats not new. Would you guys replace it now while it's in the shop?
Old Oct 23, 2006 | 06:36 PM
mhs53's Avatar
mhs53
I was reading this thread and I had the same problem this past weekend pulling my camper. I had lost power and then no start when warm. I was wondering about the answer giving about the high pressure pump problem. Whenb I crank engine the oil pressure guage doesn't move until the motor starts. Should it be reading pressure during crank cycle? I also have had injectors changed two at a time. Wonder why they just don't bite the bullet and do them all?
Old Oct 23, 2006 | 06:37 PM
Gunner15a's Avatar
Gunner15a
How long did it take for these injectors to go south? I'm wondering because I'm betting that mine are about to do the same thing...........
Gunner15a
