New engine won't start
Old Oct 22, 2006 | 10:54 PM
Steamir's Avatar
Steamir
82' F100, 300, 1bbl
Alright, just finished rebuilding my engine. Got everything hooked up today. Tried starting it, it turns over but won't run. While turning over it is very weak. I sprayed starting fluid in it, and it is getting a spark but won't start. I tried slowly turning the distributer while cranking but it doesn't work. I figured that as long as it's getting fuel (from the starter fluid) and spark then it should start with no problem. I'm stumped.
I don't know the history of this truck, it was already in bad shape when I bought it and I immediately tore it apart for the rebuild.
It's got a new battery
pistons/rings bored .030 over
cam
seals
vibration damper
Head redone
Rebuilt C6 tranny
Any advise would be appreciated.
Old Oct 23, 2006 | 05:08 AM
tewferford's Avatar
tewferford
You dist. could be 180* out.
Old Oct 23, 2006 | 06:53 AM
Steamir's Avatar
Steamir
I'll check it, but when I put it in I had the #1 piston at TDC with both the intake and exhaust valves shut/rockers up
Old Oct 23, 2006 | 10:30 AM
quicklook2's Avatar
quicklook2
bad starter, bad ground strap from engine to frame, bad/corroded battery cable or cables
Old Oct 23, 2006 | 12:42 PM
compaddict's Avatar
compaddict
First thing pop off the air cleaner and open the throttle you should see gas spray from the accel pump.
Yes?
Next since you confirmed spark, check timing with a timing light.
Yes?
Check compression with a compression tester.
Yes?
Check firing order.
If you get all the way through testing all these things in this order it will take less than a hour (as long as you don't stop after each thing).
Vince
Old Oct 23, 2006 | 03:28 PM
Steamir's Avatar
Steamir
Yes?
Yes?
Yes?
Check firing order.
Vince
Vince, how do I check the timing when it's not running?
Old Oct 23, 2006 | 04:36 PM
compaddict's Avatar
compaddict
Have you got that far yet? I'm not trying to be smart, just asking.
The same way you do when it's running. Of course someone needs to turn over the starter while you are under the hood.
Vince
Old Oct 23, 2006 | 07:52 PM
Steamir's Avatar
Steamir
I won't be able to check it until tomorrow afternoon. I had to go out of town. Thanks for the tip, I'll do that.
Old Oct 23, 2006 | 08:52 PM
compaddict's Avatar
compaddict
You did check the accel pump for gas right?
Vince
Old Oct 23, 2006 | 09:06 PM
rusted2bhell's Avatar
rusted2bhell
also check valve adjustment(lash adjustment) if they are too tight it wont run either as the valves will be open all the time
Old Oct 27, 2006 | 09:45 PM
Steamir's Avatar
Steamir
Got her started. Runs beautiful. After a year and half it's nice to see all of those hours spent come to fruition.
Lesson learned. When you think that you absolutely did something correct and it doesn't need checking....check it. It was 180* out.
I appreciate all the help. I've done alot of researching and learning on this site. And it's become an damn addiction.
Feel free to check out my updated gallery. I'll add more tomorrow.
Old Oct 28, 2006 | 10:41 AM
compaddict's Avatar
compaddict
Troubleshooting works!
Vince
