Mild info
Old Oct 21, 2006 | 08:48 PM
SirGrizx's Avatar
SirGrizx
Mild info
Hey i have a 1985 f 150 4x4 with 302 i want to give it a little bit of help in the engine department i want to change the cam and go from a 2 bbl intake to a 4 bbl intake and a 600 cfm or so carb what i want to know is what cam you guys recomend and what intake will fit on this truck thanks for your help guys
Sirgrizx
SK, Can
Old Oct 22, 2006 | 07:55 AM
Duncan10's Avatar
Duncan10
I guess it depends on what you want to do with your truck are you looking for torque for pulling or fuel economy this would change the cam you would be selecting.
Old Oct 22, 2006 | 09:07 AM
SirGrizx's Avatar
SirGrizx
well i guess i want a little more torque for pulling in the bush when i'm 4x4 ing just lookong for that little bit extra grunt i guess
Thanks
SirGrizx
SK, Can
Old Oct 23, 2006 | 09:47 AM
Kemicalburns's Avatar
Kemicalburns
what size tire and gears you running currently?
Old Oct 25, 2006 | 09:15 PM
SirGrizx's Avatar
SirGrizx
just running stock tires and wheels but will be lifting in the next 6 months or so an going to 35in tires thanks
Old Oct 25, 2006 | 09:28 PM
f100beatertruck's Avatar
f100beatertruck
Gears? Trans?
Old Oct 25, 2006 | 09:36 PM
SirGrizx's Avatar
SirGrizx
i have no idea its an auto i imagine its a c6 but have no idea on gear ratio i just got the truck a few weeks ago and i know its stock thanks
Old Oct 25, 2006 | 10:28 PM
Mil1ion's Avatar
Mil1ion
May I suggest going to the engine forum that relates to this engine .?
Or even the performance and re-building forum.
Those are the best places for engine build up questions
Old Oct 25, 2006 | 10:48 PM
SirGrizx's Avatar
SirGrizx
ok thanks guys i will go there and post my appologes for posting in wrong forum
Old Oct 26, 2006 | 10:07 AM
Kemicalburns
i would wait till you regear for the tires you plan on running then see whats needed. call compcams for there recommendation be sure to explain what you want out of your rig and what its used for. also get the exhaust done first above all with headers, and hi flow exhaust. this will make any other improvment worth while.
