Shifter help 91 F150
Old Oct 21, 2006 | 12:52 PM
M998's Avatar
M998
Hi
I believe I have the Mazda 5 speed transmission. When I pulled my transmission I took off the whole shifter assembly. The three small star screws that hold the shifter on. I can get the shifter down in the trans but it will not shift only move in the neutral position. What gives, do I not have something lined up right down in there??
Thanks in advance,
Brian
Old Oct 21, 2006 | 01:39 PM
shift1313's Avatar
shift1313
did you pull the shifter and shifter plate off the top of the tranny ? or how did you remove them? If you didnt remove the plate on the top of the tranny that does seem odd
Old Oct 21, 2006 | 03:16 PM
M998's Avatar
M998
I got it right after I made the post. The trans was in 2nd gear so I had to align the shift rails up. Thanks anyway.
Brian
ericford1984
44
Apr 7, 2012 05:29 AM
73BlackBeauty
Mar 2, 2009 05:11 PM
less
Jun 16, 2008 11:39 PM
