Modular V10 (6.8l)
surge upon start-up
Old Oct 20, 2006 | 09:17 AM
MFP's Avatar
MFP
surge upon start-up
just wondering if anyone else has the same condition. Truck is an 06 with 900 miles. Upon start-up, the rpms will go to about 1200, and stay there for about 3-4 minutes, then it will drop to around 500-750(which is where I feel it should be). If I put it in gear(it's an auto.), while the RPMs are high, it will drop to the 500-750 range--but if I hit neutral within those first 4 minutes, they will shoot back up to around 1200. Anyone else have this and know the cause?
Thanks.
Old Oct 20, 2006 | 10:13 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Sounds normal, actually.
More 3-valvers will be along in a little while to answer this...
It might need a flash (computer software) update...
Old Oct 20, 2006 | 12:07 PM
FortyFords's Avatar
FortyFords
Its Normal !,your not letting it warm up properly if you put it in gear before it drops.
Let alone the strain put to your drive line components at high rpm.
These engines are etc controlled
Rich
Old Oct 20, 2006 | 12:49 PM
MFP's Avatar
MFP
Rich
Thanks,
First V-10 after a long line of V-8s and PSDs.
Old Oct 20, 2006 | 12:59 PM
krewat's Avatar
krewat
Originally Posted by MFP
Thanks,
Not to mention, it's "fly-by-wire" throttle
Old Oct 20, 2006 | 02:05 PM
FortyFords's Avatar
FortyFords
Art, Thats what ETC means.
Old Oct 20, 2006 | 03:13 PM
Monsta's Avatar
Monsta
Sit. Stay.
FWIW, the "surge" at start-up is to aid in heating up the catalytic converter faster and to reduce unwanted emissions.
lvin4jc
19
May 24, 2011 03:51 PM
08350
6.4L Power Stroke Diesel
29
Jan 15, 2009 11:48 AM
yabo99
May 28, 2004 10:50 PM
pee wee
Bronco II
Mar 15, 2001 12:36 AM
