Sponsored by: Auxito
Instrument cluster change
Old Oct 19, 2006 | 09:49 PM
gracing's Avatar
gracing
I was wondering if there would be anyone nice enought to give me a helping hand? I have a 2001 XL F150. I want to put in a cluster panel with the factory tach. I have a factory panel from a 2003 XLT F150. I know they will both interchange physically, but what about the electronics? I see that the wiring harness is the same and the pins are the same. Am I going to have to have this reprogramed? I have done some searches and reading, isn't the PATS in the key switch and computer and not the cluster panel, except for the theft light. any help will be greatly appreciated.
Old Oct 20, 2006 | 08:56 AM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
The PCM and IC have to be programmed to talk to each other.
You'll need to have your dealer reprogram the IC.
To save a tow bill you may want to have the IC ready to remove and then drive to your dealer. Have them download the info from it then plug in the new one and upload it.
Old Oct 20, 2006 | 11:26 AM
gracing's Avatar
gracing
thanks for the info. I can get it reprogramed for $30 at the dealer. The boards inside the custer panel look different. Will this matter?
Old Oct 20, 2006 | 08:13 PM
steve(ill)'s Avatar
steve(ill)
cluster is interchangable, just needs programed.
2003EXPY
16
Mar 23, 2013 10:25 AM
LARIAT 85
May 25, 2006 06:03 PM
g0_speedracer
Oct 11, 2005 10:41 PM
JBronco
1978 - 1996 Big Bronco
Feb 10, 2005 03:38 PM
buzzer
Dec 21, 2004 01:19 PM
