Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Air Compressor - which one, which brand??
Old Oct 27, 2006 | 08:01 AM
SLE's Avatar
SLE
Well I Ended up getting a hell of a deal on an Industrial Air: I got a 5HP, 22.6amp, 80 Gallon, magnetic starter, all cast Iron, 230V, single phase, dual V belt drive, 740Rpm working, on switch at 145psi and off at 175psi. I paid a whopping $850 which is $327 less then list. It comes in handy having a very good friedn work for a large tool distributer. He was adiment that this will be a better and quiter machine then the IR that I was looking at and at $700 cheaper then the Eaton I couldn't pass it up.
Old Oct 27, 2006 | 10:18 PM
newfordguy88's Avatar
newfordguy88
Which tool distributor does he work for?
Old Oct 28, 2006 | 03:17 PM
SLE's Avatar
SLE
I don't want him to get in a bind because of me so thats why I said tool distributer, lol. He sold it to me cheaper than he probably should have!
Old Oct 28, 2006 | 05:15 PM
newfordguy88
Originally Posted by rlh
The ones I have seen didn't. That's not what I gather from their site either.
Did they specifically say "Made in USA" on them? I don't know if their model line is split, but I know someone who has one and he called the company regarding the pump...they told him it was made in China.
Old Oct 28, 2006 | 07:10 PM
Torque1st's Avatar
Torque1st
Posting Legend
Much of the noise compressors make comes from the air intake. If you enlarge and put a couple bends in the intake pipe it helps.
Old Oct 29, 2006 | 08:17 AM
stryder's Avatar
stryder
Especially if you put enlarge the pipe then run it into the attic or the garage. Makes a huge difference in noise. It also keeps the compressor from sucking in any nasty fumes while running.
Old Jan 1, 2007 | 09:48 PM
Drew2010's Avatar
Drew2010
The IG 80 Gallon is an excelent compressor. Also you may want to consider a Patton Compressor. www.pattonsinc.com They also have a very nice air piping system.
Old Jan 2, 2007 | 03:14 AM
Torque1st's Avatar
Torque1st
Posting Legend
Those aluminum tube systems are nice but high dollar! Modifications can be very expensive or even unavailable in the future. Steel pipe will be available 50-100 years from now.
Old Jan 3, 2007 | 01:21 AM
roger dowty's Avatar
roger dowty
i'm cheap and just bought a freight harbor 60 gal, 14.5 cfm @ 90 and 16+cfm @40 for 290 bucks. 6hp 130psi.
I will pick out a better pump and motor to swap out at my leisure. The things don't always have to be 'rebuildable'. For now i have a mini beast to put in the corner and I am pleased.
Old Jan 3, 2007 | 07:18 AM
SLE's Avatar
SLE
Well, I've now had it hooked up for a while and so far I'm very pleased with my purchace. I do agree though that most of the noise comes from the intake and I will be adding some piping and a larger filter. I also added a 90* bend where the petcock goes and then added a 8" nipple and a ball valve for draining out the water, it sure beats the ol screw in and out pet ***** that are always way under and out of reach.
nitro3421
Mar 5, 2011 09:38 PM
bltemple
24
Jun 11, 2009 10:30 AM
marcveinotte
May 11, 2005 12:23 AM
AKFord
Garage & Workshop
16
Oct 6, 2004 01:01 AM
Monster 78 F-150 4X4
Garage & Workshop
22
Aug 25, 2004 09:09 AM
