floor shifter
Old Oct 19, 2006 | 09:09 AM
danfish's Avatar
danfish
floor shifter
I'm doing a 302 sb & c4 trans swap into into a 1955 f-100, and I need to know will any automatic floor shifter fit right into the truck (cutting into the the floor and all ofcourse) with a c4 trans? The shifter I'm thinking of specifically is made by Lokar it's the 23" nastalgia automatic floor shifter. Any idea if of any floor shifters that would clear a stock bench seat?
Old Oct 19, 2006 | 09:45 AM
Jag Red 54's Avatar
Jag Red 54
I have the Lokar setup. The model I used is a little shorter and it was not hitting the seat even in 1st. Check my pix for location and clearance. Good luck, Jag
Old Oct 19, 2006 | 09:53 AM
uk1050's Avatar
uk1050
fit the shifter on the floor before you cut the floor to get good placement. i'm running a 23 inch lokar floor shifter with bench seats and have plenty of clearance.
Old Oct 19, 2006 | 10:12 AM
danfish's Avatar
danfish
Your truck looks awesome, thanks for the reply
Old Oct 19, 2006 | 10:42 AM
packrat56's Avatar
packrat56
I have a 302/C4 with a B&M star shifter.. Works fine but I did not do the install, the PO did..
Old Oct 19, 2006 | 11:47 AM
Huntsman's Avatar
Huntsman
I have the same 23" shifter except on an aod tranny, plenty of seat clearance. It's easily adjustable to fit close or further away, depending on how you like it.
Old Oct 19, 2006 | 11:50 AM
joe hoffman's Avatar
joe hoffman
using the same shifter but with an fmx tranny. setup a gallery with some shots if you want to take a peek. good luck, really like the way mine works.
Old Oct 19, 2006 | 12:04 PM
create's Avatar
create
here is mine. it is the lokar 23 inch like you explained on a C4/302 combo. I dont know if you can see or not, but you can move the shifter forward or back using the plate it is mounted on... with the seat in there is a decent amount of clearance in 1st gear.
Old Oct 19, 2006 | 12:06 PM
danfish's Avatar
danfish
Very cool thank you, everyone.
Old Oct 19, 2006 | 02:35 PM
53fatfndr's Avatar
53fatfndr
I'm running a B&M Quicksilver Ratchet shifter in my '53 for my C6 tranny. There are other options available from Hurst and TCI.
Old Oct 19, 2006 | 05:29 PM
propane32's Avatar
propane32
i have the 23 loctar in my 52 f1 fits nice
