Volare installed, exhaust ??
Old Oct 18, 2006 | 09:01 PM
Fordrat's Avatar
Fordrat
Ok, I got my Volare front end installed and really like it. The question now is what type of exhaust manifolds do some of you use? I was thinking Mustang headers (Fox body style) They're short and come out toward the back. Thanks for any help. I do hope this is not a double post, as I did a search and could not find anything, or just didn't know what to ask the search engine. :-)
Old Oct 25, 2006 | 06:31 PM
1955effie's Avatar
1955effie
what size engine are you planning to go with? i went with a 302 with a c4 and volare type front suspension and used the shorties like you have asked about and they worked good . i then went on ebay and found an in expensive H pipe ( about 30 bucks)because the local parts store couldn't come up with an exhaust pipe match . i only used the front section of the H pipe and fabbed the rest together from there. if you go with the shorties i think you will like them . i hope this helps . good luck .
Old Oct 25, 2006 | 08:17 PM
Fordrat's Avatar
Fordrat
Appreciate the reply. I am going with a 351w and C4. Did you have the change your oil pan to a rear sump to accomadate the front crossmember of the Volare?
Old Oct 25, 2006 | 09:23 PM
jniolon's Avatar
jniolon
old and in the way
yes... that's the only way to get the engine down low enough to fit thru the transmission tunnel. For that engine the pans are easy to find.... I think the Vans of that era used a rear sump... or some had a split sump also... they can also be bought from ford parts stores
john
Old Oct 25, 2006 | 11:00 PM
NormH's Avatar
NormH
4X4 Broncos have rear sump oil pans. Should be lots of Winstons in junk yards. I got one for my Cleveland but the doner was harder to find.
nightmare10
15
Dec 26, 2011 10:33 PM
bbussman40
Aug 21, 2009 03:07 AM
fatford55
Apr 9, 2008 11:00 PM
jaye
Jun 30, 2006 09:36 PM
55forder
Oct 14, 2004 08:23 PM
