1978 - 1996 Big Bronco
302 to 351...quick question
Old Oct 18, 2006 | 08:10 PM
wildjon300ci's Avatar
wildjon300ci
When changing from a 302 to a 351, a computer change (and for AOD a flexplate) is all that's neeeded?
(AKA same motor mounts, wiring harness still connects the same?)
Also, will an EFI intake bolt up to Edelbrock Performer heads?
Old Oct 19, 2006 | 10:15 AM
Kemicalburns's Avatar
Kemicalburns
the efi will bolt up to those heads fine. just know that the 302 intake and the 5.8 intake are not the same. the 5.0 intake also will not fit on the 5.8 motor.
you have everything else correct.
Old Oct 23, 2006 | 12:45 PM
wildjon300ci
Are you saying that the upper manifold won't fit a 5.8 lower intake? I know that the lower intakes aren't interchangable because of the 351's deck height and it being wider.
Old Oct 24, 2006 | 08:21 AM
Kemicalburns
that is correct. the 5.0 uses square bore while the 5.8 is round. I saw a 5.8 stock upper on ebay for cheap and came with the lower as well for under $80 if i recall. or get one from a wrecking yard. any 88-96 upper/lower 5.8 will work for ya
Old Oct 24, 2006 | 10:17 AM
wildjon300ci
Thanks
Old Oct 25, 2006 | 11:08 PM
LedheadELH's Avatar
LedheadELH
I'm pretty sure the upper intake for the newer 5.0's in the mustangs, have the round ports too.
Old Oct 26, 2006 | 10:09 AM
Kemicalburns
nope, the only round intake other then the 5.8 stock manifold is the Gt40 version found on the lightnings some cobra's and explorers.
Old Oct 26, 2006 | 11:09 AM
LedheadELH's Avatar
LedheadELH
O...maybe it was a trick flow setup then.....a couple friends of mine that were running Fox's had round ports, on 5.0, one of em' was a 347 stroker....and yes they were round, because I SAW them.....but I could've sworn one looked like it was a stock piece.....I dunno, maybe that one was trick flow too...?
Old Oct 26, 2006 | 01:08 PM
bronco521's Avatar
bronco521
seems like the cobra upper had round ports too.trickflows are a rectangular port.
Old Oct 26, 2006 | 01:35 PM
LedheadELH's Avatar
LedheadELH
then it may have been cobra...I don't know....all I know is that they were fricken round man!...lol....not a big fan of fox's..even though they are my friend's..they are fast as crap, but I just don't like the body....so I just kinda nod and say "Yup".....know what I mean!
Old Oct 26, 2006 | 01:42 PM
bronco521's Avatar
bronco521
the fox's aren't that bad.just kinda chintzy compared to the newer stangs.they held up well considering they were designed in the late 70's.they're alot lighter than the newer ones.
