I found a Donor 5.0 efi
I found a 1985 tbird with a 5.0 throttle body efi with an auto with overdrive.
I think the swap in it will be much less trouble with the throttle body ( I hope not as many wires)
Does anybody have any experience with the throttle body swap?
To make the deal even sweeter the guy had 2 and 1985 and a 1984Fila Tbird both with 5.0 auto/od and I got both for $900.00 drove the 84 home ran really good...
Thanks
Wade
John 3:16
Thanks
Wade
John 3:16
stay the course 87-93 stang or 87-90 lincoln mark vii forget about the rest, I got my 88 mark vii for a couple hundred complete but it was not running due to a bad fuel pump, I had a spare kicking around. That motor you are looking at puts out what 140 hp, the HO motors put out 225 have forged pistons and roller cams, and better heads.
I agree with Gary E. I went to a lot of trouble to change my carbed setup on my '49 Merc over to multi-port EFI and have never regretted it. When it came time to do my '57 F100, there was no question. NO CARBS here. The HO version of the 5.0 is just such a nice setup. Yes you could change manifold on the T-bird engine and install a carb. It is a must to get the linkage for the transmission done correctly, however.
