how hard is it????
Old Oct 18, 2006 | 05:12 PM
bigred76's Avatar
bigred76
how hard is it????
To swap out a rear tank in a 94 350?? would it just be easier to lift the bed??
Old Oct 18, 2006 | 07:59 PM
DNewton's Avatar
DNewton
well, alot of people lift their beds(i do), not only does it save your eyes from shovels full of dirt, its a lot easier to get at the tank from above then below......Dustin
just my .02
Old Oct 18, 2006 | 08:28 PM
brownieboy525's Avatar
brownieboy525
its mostly about personal preferance myself i would pull the bed. if you have a way to pull it off than i would go for it because trying to drop the tank is not fun from under the truck but you still have to go under and take the bed bolts off i think there are 6. your most likley going to have to cut atleast a few if not all because of the stupid carage bolts they use when i put mine back in i used regular hex bolts. so either way you are going to get some dirt on your face theres no way around it. the bed is not to heavy but its really akward to lift so if you have 3 other people its nice and simple. i used so saw horses and boards t0take mine off by myself.(i can only imagine what the neighbors were thinkin that lol)
Old Oct 18, 2006 | 09:36 PM
Dave Sponaugle's Avatar
Dave Sponaugle
If you are swapping out the tank, it has to come out the bottom.
Unhooking the fuel lines and gauge wires are a pain from the bottom, and there will be a lot of dirt on the tank and skid plate. But it has to come down even after the bed is off.
Old Oct 18, 2006 | 11:10 PM
fellro86's Avatar
fellro86
4 bolts and the fuel lines and fill hose, and it is out, really not that big a deal, and as Dave stated, for actual removal of the tank, it still goes out the bottom, even with the box off. I've dropped so many tanks over the years betwen cars and trucks, it really isn't that bad. My assessment is that most people make more of it than it really is. As long as you don't have an ag bumper like mine that sticks under the tank, it is pretty simple to drop it.
Old Oct 19, 2006 | 08:12 PM
Dave Sponaugle
Or a big hitch reciever like I have, it has to come off before the tank will come down.
I think the rear tank is the hardest, the cross members are in the way when trying to unhook the fuel lines.
Old Oct 19, 2006 | 08:33 PM
fellro86's Avatar
fellro86
I usually drop it down a bit before unhooking the lines. If at all possible, the tank needs to be drained as much as you can. If not, either have some help or use a floor jack with a 2x12 or such on it to help a bit. You will want to drain the tank before putting it back up.
