ABS issue
Old Oct 18, 2006 | 01:20 PM
westpsd's Avatar
westpsd
ABS issue
I am getting a C1230 code which is "Speed Wheel Sensor Rear Center Input Circuit Failure". Now since it only trips this code when moving, I would assume that it is a wheel sensor crapping out, but I don't understand why I didn't get a fault for a specific wheel....hense, I am probably wrong in my assumption.
Does anyone know where to look for this problem? I also sometimes get pedal pulsing when I hit the brakes in reverse if that clue helps. I don't show any other codes (I am using AutoEnginuity), just the C1230.
Thanks in advance...Jim
Old Oct 18, 2006 | 01:23 PM
Kwikkordead's Avatar
Kwikkordead
I think it's the VSS that you need to replace. The sender on the top of the rear axle.
Old Oct 18, 2006 | 02:55 PM
clintbonnie's Avatar
clintbonnie
Got mine from Napa.. they call it a ABS sensor, p/n530780.. $10.49. Easy to replace. Good Luck..
Old Sep 16, 2007 | 01:59 PM
mfp4073's Avatar
mfp4073
I have the same code. Thanks for the price and part number!!!
npearman
Oct 16, 2023 05:09 PM
HKusp
Oct 21, 2015 10:35 AM
2002fx4122
Mar 8, 2010 05:19 PM
