Looking for an replacement wiring harness for a 60 f100 panel mine had a little fire and needs to be replaced. Does not need to be for a restoration will be rodded out eventualy so after market ok
I am just putting the Haywire Universal 7-Fuse Kit into my 54. As Jeff said there was some discussion on this issue just recently. JUst go back a month or two.
Ron Francis wireworks... DEFINITELY!!! Particularly if you're going to rod it out later. They also have all the creature comfort add-ons that are compatible with their wiring harnesses, etc.
Ron Francis' Wire Works: 1-800-292-1940 or www.wire-works.com
hey all,i just resently joined this fine site but have been surfing around it for a while now,and i thought i would stick my 2 cents in.i have a 58'i am working on and i am installing a ezwire kit and it is agreat kit.good price to.
Hi whitehatguy44 and hot1958,
Welcome to FTE! This is the best place to be. I hope you stick around, and I look foward to hearing more about your projects.
I would recommend EZwiring.com harness due to the fact of price, it is just as good as a painless or ron frances...save the money and still get what you want...why pay a lot when you can use that extra money for more parts....
James
54 Ford F100 (302/AOD)
01 Ford Expl V6 (hers)
01 Ford SC Triton (Mines)
"If its not a Ford, then why buy or drive it!!!!!"
If you are going to rod the panel anyway this is the way I did
my 54 panel. I removed the complete Engine,wiring harness, steering collum,alternator,headlight switch from a 80S FORD car, untaped the whole thing and mounted the fuse box in the kick panel.Using the FORD collum,alternator& headlight switch made it easy.Some wires had to be lenghten/shortned and some feeds from the fuse block were not needed
the headlight switch bolted in.I routed the wires using clips I removed from the car. Then I retaped the whole thing.I ended up with
a all ford harness with quality parts with plugs that FIT.Also saved
a few bucks.
