no dip stick
Old Oct 17, 2006 | 09:22 AM
Diesel Man 03's Avatar
Diesel Man 03
Cool no dip stick
My daughter has a 03 Mercury Mountaineer with a auto transmission. This trans has no dipstick to check the trans oil level because , according to the manuel there is no need to check it.If it leaks you are suppose to take it in to the dealer and for any service or trans flush.My question is does anyone know how to check it or how to add oil to this trans?
Old Oct 17, 2006 | 01:41 PM
Ibarria's Avatar
Ibarria
jajjaaj, Man,, that is sooo crazy!
do the truck has at least a transmission oil temperature gauge?
Old Oct 17, 2006 | 03:12 PM
luxury's Avatar
luxury
I had a Caddy Catera with the same deal. You had to remove the fill flug to check the level - while the car was running! The fluid was supposed to be right at the bottom of the fill hole, sorta like checking the level in a differential. Probably the same deal with the Merc.
Old Oct 17, 2006 | 03:54 PM
Ibarria's Avatar
Ibarria
I heard the same thing in the BMW's And Mercedes, but those, supposedly didnt have one because the fluid was supposed to last a "lifetime"
Go figure...
Old Oct 17, 2006 | 04:04 PM
luxury's Avatar
luxury
Yea, the Caddy specified 100K change intervals for the tranny fluid. Seems kind of extreme to me - I'd change it more often if it was a vehicle I planned to keep for a while.
Old Oct 17, 2006 | 04:36 PM
Ibarria's Avatar
Ibarria
yeah I have a 2000 Cadillac Deville, and it has a Tranny oil life monitor, the thing is, it has 90K miles, I changed the oil at 50K and the monitor is still showing me 100% tranny oil life, hard to believe huh.. so I will be changing the fluid this weekend after 40K miles. It calls for DexronIII Syn Oil. and it needs about 9 or 10 besides it has no filter :P, because the main filter is internal and is only changed when the tranny is rebuild.. bad bad bad..
greetings..
Gerardo.
Old Oct 17, 2006 | 04:43 PM
vloney's Avatar
vloney
that there is genuine jaguar engineering! Its the same trans in the "s" type. To check the oil, the plug on the bottom has a big plug and a smaller one inside it, remove the small one at operating temp while running. It should dribble out of there if full. To fill it, it goes in the same way. Get a squeeze bottle, and rig you up a tube that will go inside the small hole and start squeezing!
Old Oct 17, 2006 | 04:53 PM
Ibarria's Avatar
Ibarria
well.. I sure like better the Old way..
Old Oct 17, 2006 | 05:06 PM
Mr.Novice's Avatar
Mr.Novice
Was looking at my sister's Chevy Malibu the other day for her. Searched for 10 minutes for that dang dip stick only to read later that "There's no need to check the fluid level. The only reason it would be low is because of a leak". Well, the car is a POS anyway, but that blew my mind.
Copedawg
Nov 21, 2010 10:37 AM
Taffy.C
Aug 31, 2007 07:32 PM
Jay03
May 13, 2006 08:09 AM
weatherl
Feb 5, 2006 12:50 AM
blown5.0
Apr 30, 2004 02:49 PM
