Info on Flathead cooling itemsand then Sum
Hi guys I need a few Questions answerd if posible please.
What type of thremostats do I need on my Ford 1934 V8 Flathead, Bellows type or Reg new flathead type? Do I need 2 for each water inlet?
On my motor the water pumps are up front , and was told the Temp sensor was thier , can anyone give me info on ware to obtain one? part #etc?
Would anyone have and accelerator Motor Bracket and Rod. My motor is in a tracktor so the Engine is in the rear and i'm up front with the radiator behind my left ear.And all the mechanicl linkage is up front.
Fuel pump push rod , What is the correct lenght of a fuel pump push rod in my motor, Also I believe it calls for a Brass Bushing , But I don't see ware it fits in? does the 1934 to 1937 flattys have the Brass Fuel Push rod Bushing?
I don't know how to post pics yet but that will explain my Novice information better. Cheers Mike
Grenidier
Try this web site it may help you in what your looking for.
http://www.vanpeltsales.com/FH_web/flathead_home.htm
