Hi and thanks again to those who responded to my wheel question. That information and subsequent research has led me to reconsider the whole running gear of my 47 1 ton. It seems that a " big " ford 9' rear, C6 and front disk brakes, along with some type of power steering might make a much more drivable and safe vehicle.The motor has been changed in the past to a 53, and the 4 speed is badly worn so it would not be the loss of a perfect original , and I would keep the truck stock in appearence . Has anyone combined a C6 with a flathead ( rebuilt with upgraded waterpumps, new heads etc. for a little extra power ) or is that a bad idea. ( I see that Speedway offers a transmission adaptor for this combo at least ) . If its do-able what rear end gearing is feasible. I plan to do light hauling and cruising. The days of overloaded lumber deliveries are past for this truck. Thanks!
My only hesitation about using the C6 is that it draws a lot of HP, which flatheads don't make tons of to begin with. A C4 uses less power, is lighter, and more readily available. If the truck will not see any heavy use then I would favor the C4 over the C6.
I agree with Gary re: the C6 vs a C4. Also most C6's have an integral bellhousing as part of the case. I'm not sure what Speedway is selling for adapter, but check into it.
If you have a 53 flathead you have the best stock heads Ford ever made and are better than most aftermarket 'improvements'. I'd run the EAB heads. Stock waterpumps are more than adequate - no need for fancy, expensive 'upgrades' here either.
I'd really suggest running as close to stock as you can - you can always add improvements later if you feel the need. Go with a C4 and I think you'll like it.
