Alternators instead of generators!
Old Oct 16, 2006 | 11:16 PM
HT32BSX115's Avatar
HT32BSX115
Howdy all!
I'm going to put an alternator in my truck when I put the rebuilt 292 in.
Does anyone have suggestions as to which one is easiest to install?
I'm expecting to have to fabricate my own mounts of course.
I'll use a single wire type alt with an internal regulator capable of at least 80-100 A.
I already have a Bosch unit from a VW car that might be ok but I'd like to use something that is sort of generic.
Any ideas?
Thanks,
Rick
Old Oct 16, 2006 | 11:57 PM
ALBUQ F-1's Avatar
ALBUQ F-1
That Bosch VeeWee unit is the most unreliable POS on earth IMHO. They cost $300 rebuilt!! Sell it to some poor soul with a dead VW, it will pay for a GM 1-wire and mount. I can't believe you can't just buy a ready-made mount for a Y-block?
Old Oct 17, 2006 | 12:01 AM
TheSovereign53's Avatar
TheSovereign53
Wont the GM give the 292 cooties? (Im glad that old vee-dubya unit is a paperweight in my garage)
Old Oct 17, 2006 | 12:21 AM
HT32BSX115's Avatar
HT32BSX115
Well I do have an alt from a Cessna......I suppose I coule bolt it on there.......That would make my old truck fly!
Old Oct 17, 2006 | 05:04 AM
Walston's Avatar
Walston
This is what we did on our 292. http://www.ranchwagon.com/tech/alt/alt.htm
We have a 1-wire (self exciter) alternator we bought at Advanceauto. If I remember correctly, it was about $60 for an 80 amp.
good luck
Old Oct 17, 2006 | 06:18 AM
GreatNorthWoods's Avatar
GreatNorthWoods
The GM alternator is probably the closest thing to a "generic" as you can get. The one-wire is the easiest to hook up. I used a 3-wire only because I already had one from an 86 Buick I salvaged. The extra two wires are not a big deal either if you decide on a used one.
Old Oct 17, 2006 | 03:40 PM
HT32BSX115's Avatar
HT32BSX115
When you say "3 Wire" you mean a unit that will require an outboard regulator?
I will want one with the voltage regulator inside I think.....
I suppose I could build a simple regulator. And that might be good since I could design it for current fold-back and better filtering etc.
The ARRL Radio Amateurs Handbook has an excellent VERY simple and reliable solid state regulator for Alternators that shold cost no more than $15 or so to build.
Thanks!
Rick
Old Oct 17, 2006 | 05:55 PM
low54's Avatar
low54
GMsingle wire is the way to go, remember if your changing from 6v to 12v change your bulbs and add resisters to your heater,wipers and lights
Old Oct 17, 2006 | 06:27 PM
TheSovereign53
EWWW whats with all the GM alternators??? Wont they hinder your performance? You would have to put some of those awful NUTZ on your truck to make sure it is alright!
Old Oct 17, 2006 | 07:01 PM
HT32BSX115's Avatar
HT32BSX115
Not a problem here....someone changed this thing to 12v sometime back when I was in high school!
GM alternators.........hmmm......YOu know it seems that AC Delco alternators have been used for years on Fords with no ill effects.....just like Motorola, Prestolite, and....... $%^&....... Bosch!
Man! I think I have an Autoliite on My Suburban!
Old Oct 17, 2006 | 11:08 PM
Geoles's Avatar
Geoles
Just cause I have no clue, why would you put a GM wiring harness and a GM alternator on a Ford??? What would be the difficulty with, ummm, using a Ford product??? It seems to me that there must be something to be said for keeping my 56 equiped with Henry's finest...If a guy is willing to continue pulling a distributor cap to set dwell, why shouldn't he stay with a Ford electrical system??? Not trying to be sarcastic. I really don't know.
Old Oct 17, 2006 | 11:43 PM
HT32BSX115's Avatar
HT32BSX115
Well,
The GM ALT we are talking about only requires 1 (one) wire to hook up.
there is no harness.
Old Oct 17, 2006 | 11:54 PM
ALBUQ F-1's Avatar
ALBUQ F-1
This is called "hot rodding", using the best components regardless of origin.
Henry's "finest" (assume you mean a Ford/Autolite alternator, not a generator) is honestly just not as good as the GM 1-wire; there's nothing "wrong" with it, but neither is original, so given the choice, most people choose the better value.
No harness is needed with a 1-wire, just the one wire. To people trying to show off their engine, the cleaner look is a factor. The Ford alternators use 3 wires, and you have to mount the regulator somewhere nearby. The regulator costs another $20 or so, too.
Most people aren't pulling their cap to set dwell, they are using an electronic distributor. Again using superior parts.
Mind you, I'm not one to torch frames for IFS/IRS or T-5's or other Dark Side stuff, but the electrical system is the heart of any vehicle, and it took me all of a week of screwing around with the 6v generator system to come to the conclusion that an alternator was the way to go. And I'm working on a MoPar electronic distributor for my flathead.
Old Oct 17, 2006 | 11:59 PM
TheSovereign53
Well, this is something every ford purist hates to admit, but for money and parts availability, a SBC can't be beat. I know that everyone always says "oh I am so sick of 350's in every car I see!" But don't you think there is a reason every car has a 350 under the hood? Of course, the cooties stuff I was saying is my normal poor sense of humor, but when you think about it, why not put a SBC in your truck if you are swapping around Eng/Trans?
Old Oct 18, 2006 | 12:11 AM
HT32BSX115's Avatar
HT32BSX115
Well, I'm not going that far yet!
I just spent about $2k getting my 292 rebuilt, balanced, ported etc.
Down the road I'll put a 6BT in it but I intend to drive this thing a while with the 292!
I wanted an alternator because generators generally suck!
