390 PI questions
I think the key question here is, what pistons are in it, and if you're not using those, which pistons are you going to use? You need that to know about what compression ratio the thing will have.
There are still so many things that affect it. One, headers or no? Big difference there. What's the CFM of that carburetor? Doing any head porting? Putting in the stock valve size or bigger?
Depending on those things, could be anywhere from 314hp to 443hp.
That must be an old cam; as the Isky 270 degree cam data I have shows .510" lift.
So, are we talking TRW L2291's for the pistons? Good units. I dont think it'll get you 10:1 though, as they're listed at 10cc's of valve reliefs. I dont know if I believe it though.
Concerning the heads. It's actually possible, to make them flow about the same or a little better than the stock Edelbrock heads! Especially the earlier heads like you have. What you have to do, is port them. Remove all the casting roughness, take the intake to about 80 grit, and polish the exhaust port to a mirror finish. Smooth up the short side radius. Clean up any ridges in the bowl area. If your heads have an emissions bump on the top back of the exhaust port, that can be ground off. Port work goes a long way with these things. Also, you could notch the cylinder bores and put in CJ size valves.
Headers are an extremely good idea. I guess I'd start with headers for a later truck that came with an FE. If they dont work, send 'em back. If you're good with a welder you could try making a set; something I've never done. All I can say there is good luck. But if Desktop Dyno is any indication, it's well worth your while.
These heads really dont need to be "hogged out". They really like a good cleanup job though. You know, smooth it out, round it off. If you know a someone who knows how to port an FE head, by all means. It's a long, boring, dirty job.
Here some pictures, but these are the final head porting pictures. But you get the idea.
https://www.ford-trucks.com/user_gal...=129541&width=0
https://www.ford-trucks.com/user_gal...=129542&width=0
https://www.ford-trucks.com/user_gal...=129573&width=0
https://www.ford-trucks.com/user_gal...=129574&width=0
https://www.ford-trucks.com/user_gal...=129575&width=0
https://www.ford-trucks.com/user_gal...=129576&width=0
Here the ultimate head porting finish https://www.ford-trucks.com/user_gal...=58615&width=0
https://www.ford-trucks.com/user_gal...=58593&width=0
courtesy of Kurt.
