Service engine Light
Old Oct 16, 2006 | 09:23 AM
weekendwander's Avatar
weekendwander
I have a 2001 Ex with v-10 and 4.30 that I bought a few months ago used.
With cold weather I found out that the heated seats were not working. I wanted to make sure the fuse was OK but, pulled the wrong one while the truck was running.
Since then the SES light is on. Any ideas on what could have caused this and how to clear it?
TIA
Old Oct 16, 2006 | 01:36 PM
MarkMoore's Avatar
MarkMoore
Don't know what fuse you could have pulled, so don't know what caused it.
You can take it to AutoZone and they will scan and clear the codes for you for free.
What lind of mpg are you getting with the 4.30 gears? I'm thinking of changing from the 3.73s to the 4.30s and trying to decide if it's worth the $$.
Old Oct 16, 2006 | 02:55 PM
weekendwander
I pulled a 50Amp fuse from the under hood compartment. Didn't think anything about it until this morning when I saw the SES light so I don't recall what it was labled.
With the 4.3 I get 11 around town (17 miles each way about 3/4 are mostly city the remaining are country type roads)
Pulling my 7500 LB travel trailer I am getting 8.5 to 9.2. It is a really nice pull and I leave it in OD since at 55 I am just below the power band and don't have issues with it hunting for gears.
I really got lucky, I just assumed it was 3.73 when I looked at it. After driving I was pretty sure that it was 4.3 and wasn't going to buy it because of the gears. In the end I don't really think it matters except for towing where I can use OD. Of course if I communted on the highway where I would travel at 70 it would really be sucking down the gas because of the engine speed.
Old Oct 17, 2006 | 09:17 AM
weekendwander
Problem solved. the number of Key cycles to clear the light was more than I thought (must have been 50 or 100) This morning after stoping to get gas (boy I seem to do that often) the light went out.
