Possible injector trouble
Old Oct 16, 2006 | 08:30 AM
Whopper809's Avatar
Whopper809
Does anyone know if any injector problems would be covered by warranty or do they consider this not part of the power train?
I have my 03 6L sounding like a 7.3, sometimes a CUMMINS on cold morning startups, but once warmed up it runs smooth. Has to be a bad injector, anyone have a idea?
Old Oct 16, 2006 | 11:39 AM
BowTieHatr's Avatar
BowTieHatr
injectors are under the 5/100000 warranty. it could also be the icp sensor leaking oil shorting out the readings.
Old Nov 2, 2006 | 10:45 AM
coxstar's Avatar
coxstar
2005 F350 PSD. had cold start and run problems, seemed like missing on at least 2 cyl. was a couple bad injectors, replaced under warranty at 60,000 miles. Now I have 125,000 miles and the same cold problems are back. I will take it in soon.
Old Nov 2, 2006 | 11:52 AM
l-m tech's Avatar
l-m tech
Ford Is Fixing To Release A New Reflash For Cold Weather Operation.ford Says That In Cold Weather The Spool Valve Can Stick And Cause A Miss .if The Miss Goes Away After The Vehicle Warms Up This Is More Than Likely Your Problem
Old Nov 2, 2006 | 12:06 PM
vloney's Avatar
vloney
its already been released for a week or two
Old Nov 2, 2006 | 12:39 PM
l-m tech's Avatar
l-m tech
Has It Fixed Any Trucks Though.it Isnt Cold Enough Around Here Yet To Tell.
Old Nov 2, 2006 | 07:27 PM
CanadaGuy's Avatar
CanadaGuy
I've had great success with it. I've done 4 in the past week, and it's been below freezing each morning when I've cold started them... all ran great.
Old Nov 2, 2006 | 08:04 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Is it going to do anything else, like something we will not like
Old Nov 2, 2006 | 08:10 PM
vloney's Avatar
vloney
Not to my knowledge. It only addresses the cold start issue. So far, I havent seen any downside. Now, before you run right down to get your cold start fix, remember, all the other "upgrades" will be included.
Old Nov 2, 2006 | 11:25 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
vloney, do you happen to have the processor code or calibration number for the new flash? Can't seem to find it.
Old Nov 3, 2006 | 06:32 AM
vloney's Avatar
vloney
I'll have to run it down. We dont have it at our fingertips either. When one gets flashed, the message shown is "a later calibration is available, do you want to reprogram? yes or no?" After recalibration it has "IF REQUIRED, affix recalibration notification under hood" The only numbers shown is the part # for the pcm.
