Still starting problems
Old Oct 16, 2006 | 08:16 AM
acdc's Avatar
acdc
Red face Still starting problems
<HR style="COLOR: #ffffff" SIZE=1> <!-- / icon and title --><!-- message -->
93 F150, 302, automatic, 189,000 miles.
I had problems and codes. Got all of the codes cleared by fixing the problems.
Still I have a problem on the first start of the day. The only way I can get it to start is to cover the throttle body while cranking and it finally hits and starts.
It is getting fire. I have changed the plugs and checked the fuel pressure, all okay. Ran fuel pressure test on both tanks and they are okay.
I am pulling my hair out (both of them).
Any suggestions????????
Oh yeah the only code i am gettin is 11 which means all is good.........
And also once I get it going, it starts the rest of the day???
Old Oct 16, 2006 | 08:30 AM
subford's Avatar
subford
You have a vacuum leak and it could be:
1. EGR Valve open
2. Intake gaskets
3. Vacuum or vapor hose off or broken
4. PCV valve bad with dip stick not sealing
Old Oct 16, 2006 | 09:38 AM
acdc's Avatar
acdc
I checked for vacuum leaks with starting fluid and visually. any other suggestions on how to check for that?
Also some of the lines are brittle and i have replaced them with rubber instead of the hard plastic original. is there someplace reasonable to get the replacement hoses already precut, i will try replacing them all and see if that works. it driving me crazier.
THANKS
Old Oct 16, 2006 | 10:51 AM
acdc's Avatar
acdc
also forgot to mention, have replaced the pcv valve and checked and cleaned egr...could it be some sort of problem with injectors?? is there an easy way to clean them or check them?? not that up on ejectors but easily taught when it saves me money...
Old Oct 16, 2006 | 10:56 AM
DAJF150's Avatar
DAJF150
Some of my sm. black plastic christmas tree lines on the intake, and the ones comming out of the HVAC stuff have crumbled as the plastic gets brittle. I took sm. diameter rubber air line hose, 1/8 or 14 inch and cut up to the good plastic line and slid the rubber line over to replace the damaged/old part. It has worked fine.
Old Oct 17, 2006 | 07:19 AM
acdc's Avatar
acdc
where is a good place to get the replacement vacuum hoses that are color coded?
Old Oct 17, 2006 | 08:25 AM
subford's Avatar
subford
Sometimes over looked for a big vacuum leak is a ruptured brake booster diaphragm.
Also bad heater/AC controls in the cab can be a vacuum leak too, just had one of these yesterday. Did not stop it from starting but it did run rough.
Old Oct 31, 2006 | 08:53 AM
acdc's Avatar
acdc
Have replaced EGR, checked everywhere i can find for leaks. The only thing i haven't done is taken the intake off and checked it but it hasn't been too long since i had it off and put on a new gasket when i put it back on. any ideas on how to check for intake leak?
Old Oct 31, 2006 | 09:18 AM
nighthawk285's Avatar
nighthawk285
do the propane test. find something like those small torches that you spin on top of a coleman propane tank, and rig it so that it doesnt fire,but instead just spits out gas. then, with your engine running, take the gas and run it down along the gasket line that you're wanting to check. if the gasket leaks, the propane will get sucked in, and the engine will rev up a little.
Old Nov 1, 2006 | 07:35 PM
acdc's Avatar
acdc
Okay today i pulled the intake plenum off.
SInce my cats are gone i took the dangling pipe off (thermactor and crossover) plugged it. Checked all vacuum lines. cleaned everything. New gaskets put it all back together and still same problem. NO START......so does anybody have any idearsssssssssssss
Old Nov 1, 2006 | 09:25 PM
subford's Avatar
subford
How did you check the fuel pressure?
Old Nov 2, 2006 | 06:06 AM
acdc's Avatar
acdc
checked it with the key off, key on, engine running, both tanks, don't remember exactly but it was between 35 and 40. problem has been deteriorating. could get it started but now it won't
Old Nov 2, 2006 | 06:07 AM
acdc's Avatar
acdc
what about a cam or crank position sensor, does it have one?
and where is it?
Old Nov 2, 2006 | 06:24 AM
subford's Avatar
subford
and where is it?
The cam sensor is inside the distributor.
Old Nov 2, 2006 | 06:32 AM
acdc's Avatar
acdc
could this be a problem?
