TAG LIGHTS help
Old Oct 16, 2006 | 06:12 AM
Quicktoy's Avatar
Quicktoy
TAG LIGHTS help
OK i feel like a moron but looking in the owners manual, I cant find which number fuse is the license/tag light. both my lights are out and figured check the fuse before i try anything else. its an 03 limited with a 6.0 PSD
Old Oct 17, 2006 | 09:11 AM
5-Ryersons's Avatar
5-Ryersons
Should be fuse #17, 15Amp, but that controls "exterior lamps". Check the bulbs, or see if there's a connector that's come undone.
Old Oct 17, 2006 | 11:28 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Always check the bulbs first; they're cheap and easy to check unless you have huge hands like me. I'd get it done asap too, a state trooper pulled me over just for that. He must have been in a great mood becuase he let me off with a warning.
Old Oct 17, 2006 | 02:09 PM
Quicktoy's Avatar
Quicktoy
yup it was the bulbs, with the hitch in the way theyre a bitch to pull out, thanks guys for the help
Old Oct 17, 2006 | 10:03 PM
RACERX7775's Avatar
RACERX7775
yeah, i just had the same problem. i tried to get the lenses out because i could not get my hands behind the hitch and wound up breaking the lights. oh well, cost me $16 for 2 new tag light housings and bulbs.
Old Oct 17, 2006 | 10:33 PM
caddys83's Avatar
caddys83
That trailer hitch does suck when your trying to remove the light bulb. I had my fair share of squizing my hand and bending my arm awkward (sp?) Those lens housing appers that you can pop them off with a flat head screwdriver but I learned the hardway.
Old Oct 17, 2006 | 10:39 PM
RACERX7775's Avatar
RACERX7775
the screwdriver thing doesn't work, thats how i broke the tabs off mine.
Old Oct 17, 2006 | 11:35 PM
Quicktoy's Avatar
Quicktoy
ya theyre so brittle, i broke one today and am afraid to atempt the other tomorrow as i know im gonna have to go right back to ford to get the other housing LOL
Old Oct 18, 2006 | 10:14 PM
rograbbitt's Avatar
rograbbitt
I got to mine through the license plate area as i broke the first one i tried with the screwdriver....good thing i had a hot glue gun
Old Oct 27, 2006 | 09:39 AM
Quicktoy's Avatar
Quicktoy
ok i put the new bulbs in...still dont light up. the white bulb housings look almost burnt. guess i gotta go to ford today to pick up new housings :-(
Old Oct 27, 2006 | 10:53 AM
turboale's Avatar
turboale
If you spend the dime on a new housing, I would go ahead and buy some LED replacement bulbs. If you put the same bulbs in they will get just as hot and melt the darn things again. Stupid design by ford...
Light bulbs 1
Ford 0
Old Oct 27, 2006 | 11:51 AM
Quicktoy's Avatar
Quicktoy
just priced a new wiring harness for the tag lights from ford----like 145 dollars. anyone recommend another idea. does discount or napa sell just the piece that holds the bulbs and i could wire it in to te stock wiring?
Old Oct 27, 2006 | 11:08 PM
RACERX7775's Avatar
RACERX7775
Smile tag light harness
yes, you can go to your local parts store and just ask for a ford 194 bulb pigtail end. then just splice it in. very easy and cheap too. they are like $2.50 each...
Old Oct 28, 2006 | 11:10 AM
Quicktoy's Avatar
Quicktoy
omg thankyou so much
armour01
2004 - 2008 F150
Oct 16, 2012 02:11 AM
mntncat
May 17, 2012 02:44 PM
rockos3354
Escape & Escape Hybrid
Sep 23, 2010 07:02 PM
glenerd51
2004 - 2008 F150
May 18, 2009 09:23 PM
