exhust whissle
Old Oct 15, 2006 | 08:37 PM
sleepyhead416's Avatar
sleepyhead416
exhust whissle
I did the napa aircleaner & straight piped my exhust on my 2003 f-350 7.3 mileage went to 13.3 thats GREAT for a dulley but when I start on cold morning and itstarts to go to fast idle it has a sharp whissle out of tailpipe if I kick it off of fast idle it go's away. could I be having trouble with wastegate?
Old Oct 15, 2006 | 08:42 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
yep, that is normal operation. it is the Exhaust Backpressure valve closing. it is a butterfly valve in the exhaust that restricts about 95% of the flow. the exhaust is forced through the small area that is not closed off, thus the hissing noise. this design holds the heat in the engine, allowing for faster warmups. it was hard to hear with a stock exhaust, that is how restrictive they are. once you open it up, you hear everything.
Old Oct 15, 2006 | 08:48 PM
sleepyhead416
so there's no fix to this ? just let it be?
Old Oct 15, 2006 | 08:51 PM
BuickTurbo's Avatar
BuickTurbo
You can un plug the EBPV. Under the compressor housing, front pedestal, water pump side of turbo (front).
Old Oct 15, 2006 | 10:50 PM
Tenn01PSD350's Avatar
Tenn01PSD350
No fix needed unless you want to disable the backpressure valve and warm up a bit slower when it is cold.
