compression
Old Oct 15, 2006 | 08:08 PM
pabs's Avatar
pabs
Talking compression
thanks for all the input.Dave ill try loosing the #5 rockers and force air in.
This the best forum ive ever been in.I like the chat.
Old Oct 15, 2006 | 08:58 PM
Dave Sponaugle's Avatar
Dave Sponaugle
So do we.
I had a run of bad reman motors, I got rather good at finding cracked blocks, blown head gaskets, cracked heads and changing motors.
With a couple helpers I can swap the engine in my truck in 8 hours now.
Old Oct 15, 2006 | 09:24 PM
pabs's Avatar
pabs
ive also noticed on the 91 f-250 when i had it towed home th coolant level is low.two days before i brought home level was up???truck ran when got home even with no compression in 5.now it wont start:-{.
Old Oct 15, 2006 | 09:38 PM
Dave Sponaugle
Be careful, if the cylinder is full of coolant you can bend or break expensive engine internals like the crank or connecting rod. Water does not compress.
Old Oct 16, 2006 | 11:10 AM
Hamberger's Avatar
Hamberger
As Dave said, it's funny how fast you can get something done when you have done it a few times before.
I just spent part of my weekend replacing a cracked front cylinder head on my 3.8l in my Windstar. After I fired her up I got a misfire and No.2 cylinder which is the rear head which looks to be also cracked. With all the tools at hand it took me 1 hr 45 min till I got the rear head off and that included a 20 minute return trip to the autoparts store to pick up a 13mm 1/2" drive deep socket to get those darn exhaust manifold bolts off.
Who was that guy that put aluminium cylinder heads on a cast iron block?
Seb....
Old Oct 16, 2006 | 06:41 PM
pabs's Avatar
pabs
Seb....
Hey man thats so true shoot the guy.How long would it take to tear the heads of the 92 ford idi passenger side
Old Oct 17, 2006 | 08:55 AM
Hamberger's Avatar
Hamberger
That is the beauty of these diesel trucks, I have never had to remove a head on any of mine yet. Of course it helps if you buy good quality BERU glow plugs.
Seb...
Old Oct 17, 2006 | 10:10 PM
Dave Sponaugle
The passenger side is the hard one, the heater/AC box is in the way.
With air tools you are looking at about 6 hours.
Pull air cleaner
Pull IP and injection lines.
Pull alternator
Pull vacuum pump
Pull the brackets for the above
Pull the fuel filter and bracket
Disconnect the wiring harness, chassis to engine
Pull exhaust manifold
Drain the coolant
Pull intake manifold
Remove the rocker cover
Remove the injectors and glow plugs from that head.
Remove the heater hose from the head.
Removing the thermostat housing gives you more room to manuver the head.
Remove the head bolts, this is where it gets hard, some of the head bolts will not have room to pull out of the head. You need to use some fuel line about 2" long that is split down one side to slide over the head bolts to hold them up. I think there are three bolts that need this.
The head is rather heavy, an engine hoist makes it much safer for you and the head during removal from the engine bay.
Hood off also gives you much more room to sit in the engine bay while wrenching.
If you have a turbo it is much easier to pull the engine before you take the head off.
Old Oct 17, 2006 | 10:30 PM
pabs's Avatar
pabs
sounds like quiet the task.Im a mechanic but new to deisels.6 hours huh is it any diff then a gas pot???Thanks for the speal.any speacial tools needed?Cant i leave the ip in?? looks like it will work?Injectors a must though.Thanks for the response you are quite knowledgable.Talk to you soon.I have anothre question i have a truck at work that turn key and glow plug lites 2 sec and big time clicking, is there a relay or a control that makes it click?Or is that normal?Can you help?please
thanks pabs
