Wicked wheel Dissappointment
Old Oct 15, 2006 | 07:03 PM
DCH614's Avatar
DCH614
Well I finally install the new wheel, it moves the exhaust better, but disapponited in the lack of sound, any suggetions?
Old Oct 15, 2006 | 07:04 PM
Uzumati's Avatar
Uzumati
Have you removed the foil from the IC pipe and gone to an "open" intake (Kwikk)
Old Oct 15, 2006 | 07:05 PM
DCH614's Avatar
DCH614
nope everything is stock form
Old Oct 15, 2006 | 07:13 PM
Uzumati's Avatar
Uzumati
I noticed the most sound increase from taking the foil off and then a liitle more when I ported the AIS to the fender. When this filter gets dirty I think I will switch to the Kwikk filter to increase the whistle a little more
Old Oct 15, 2006 | 07:27 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
how does it move the exhaust better? the wicked wheel is a compressor upgrade, not the other side.
i also agree with amiller, the IC foil removal makes it sound a whole lot better. it kept me satisfied for a little bit. plus, it's freeeee!
Old Oct 15, 2006 | 07:32 PM
DCH614's Avatar
DCH614
maybe the little bit of added boost, it throws more black smoke than before under acceleration
Old Oct 15, 2006 | 07:47 PM
BuickTurbo's Avatar
BuickTurbo
Added boost? You actually removed a neglegable amount of boost.
Old Oct 16, 2006 | 10:09 AM
Scar13's Avatar
Scar13
My WW didnt make any more noise then my original wheel did...
and I Tymared, and removied the foil....
Old Oct 16, 2006 | 10:25 AM
MTDewX's Avatar
MTDewX
But does it work better than the regular turbo wheel?? worth the money on the butt dyno test? how about fuel mileage??
Old Oct 16, 2006 | 11:07 AM
kbeefy's Avatar
kbeefy
More smoke means either more fuel going in (too much) or less air (boost). Black smoke isn't really a good thing, but it's cool!
Old Oct 16, 2006 | 02:54 PM
Scar13's Avatar
Scar13
If I did it over, I wouldnt get it... but I dont tow very often either so I dont see much turbo surge.
You wont see any butt dyno because you lose a snmall amount of air flow with it.
Old Oct 16, 2006 | 02:58 PM
Lance_I's Avatar
Lance_I
The WW isn't really supposed to make it whistle louder. It's only supposed to help out with surge.
Old Oct 16, 2006 | 03:50 PM
Tenn01PSD350's Avatar
Tenn01PSD350
??? I thought Ford went away from the previous design AKA wicked wheel now specifically because of the noise/whistle and even put foil on the IC pipe to further eliminate noise. A side benny was better low end boost but at the expense of surge. Do I have this wrong?
Old Oct 16, 2006 | 05:48 PM
BuickTurbo's Avatar
BuickTurbo
I'm starting to think that Ford , tuner manufacturers, chip amnufacturers, and aftermarket hard parts manufacturers get together every friday after work. They make ill fated bar bets together and that is how we get the crap we buy. What do they call that? "planned obsolesence"....
As far as our stock wheel and the whicked wheel go, I think Ford was trying to add more power at the least amount of expense. The loss was the surge/flutter, the gain was the "enthusuasts" buying the old parts left around.
Old Oct 16, 2006 | 05:59 PM
ryaneverk2's Avatar
ryaneverk2
I'd say you have that right!
