Another hard-cold-start question
Old Oct 15, 2006 | 06:20 PM
MikeSDK's Avatar
MikeSDK
I have checked on the 'oifficial cold start thread' to try to determine why I'm having such difficulty starting the past few days https://www.ford-trucks.com/forums/4...oke-thread.html
but I still have a few questions.
It has just dropped into the 30s here at night, and the past couple of mornings I've had a tough time getting the truck to turn over. Plenty of cranking power from the batteries, just won't come to life. What it does do, however, is put a ton of smoke in the air. Not the pleasant diesel exhaust smell we all love, but more of a choking cloud.
Is this an indicator that I have glow plugs out? If so, how do I determine which to replace?
Alternatively, were some truck produced with a block heater, and some not?
Thanks
Old Oct 15, 2006 | 06:23 PM
Muktown's Avatar
Muktown
i think all had a block heater it may just be hard to find. next time you go to start it turn on the key and go out and bridge the glow plug relay with a screw driver. if it works then you need a new relay. if it doesnt you might have to replace the glow plugs but it does sound like a glow plug system problem my guess would be the relay
Old Oct 15, 2006 | 06:26 PM
Uzumati's Avatar
Uzumati
Pull the harness connector out of the valve cover connector and you will see 9 pins the outside 2 are the GP's check resistance to ground should be 3 - 4 ohms if it is >20 it is a bad GP
Old Oct 15, 2006 | 07:19 PM
RocketScience's Avatar
RocketScience
Originally Posted by MikeSDK
.....Alternatively, were some truck produced with a block heater, and some not?
To my knowledge, all PSD were produced with block heaters, they're just hard to find if it was never used before.
