4 or 2 cats???
Old Oct 15, 2006 | 04:07 PM
is300wrx's Avatar
is300wrx
4 or 2 cats???
Does anyone know when Ford started to put 2 big cats in our trucks instead of 4 small ones??? I have a 4.6 and its a 2005...I beleive its an early 05, and when I went underneath the truck, I can clearly only see one on each side...
Old Oct 15, 2006 | 04:35 PM
paul812's Avatar
paul812
OBDII required 2 cats per side (to pass emssions) since '96 or '97. all cars, & light trucks. I think certain larger engine sizes were exempt at the time, but emssions req. gets more strict as the yrs go by. paul
Old Oct 15, 2006 | 04:39 PM
is300wrx's Avatar
is300wrx
i know for a fact that 04 had 4 cats...But Ford changed those specs to 2 cats...When and for which engine did they do it for? I have a 4.6 and thats why i am asking
Old Oct 15, 2006 | 04:50 PM
veronese1's Avatar
veronese1
4.5 is when it changed. the 3v motors went back to 2-cats.
And the older models did not have 4-cats. They had 2-catalyst pre-heaters and 2-catalytic converters.
Old Oct 15, 2006 | 05:44 PM
is300wrx's Avatar
is300wrx
so my 2005 4.6 v2 only has 2 cats??? Because i been reading alot about how the 04 have 4 cats and people were removing the 2 rear most cats...
Old Oct 15, 2006 | 07:16 PM
Bob Jusnes's Avatar
Bob Jusnes
i dont know the cut off date, but the 04s did have 4 cats, sometime in 05, ford stopped using the rear ones. If you only have 2, then you are better off and should be happy!
Old Oct 15, 2006 | 08:59 PM
efx4's Avatar
efx4
My 05 with the 5.4 has 4 cats. There are 2 pre-heaters off the exhaust manifolds, an 1 at the y pipe, and one after the y pipe. My truck has a build date of 6/05.
Old Oct 15, 2006 | 09:01 PM
Bob Jusnes's Avatar
Bob Jusnes
that is strange, on the 04 there are 2 cats on each side, all before the Y pipe. With the o2 sensors between them, making the removal of the rear ones painless
Old Oct 16, 2006 | 08:15 AM
is300wrx's Avatar
is300wrx
that's why I asked....I only have one on each side and after the Y pipe, I have nothing..i guess i should be a happy camper
Old Oct 16, 2006 | 01:54 PM
Bob Jusnes's Avatar
Bob Jusnes
its strange that you even have one after the Y pipe, maybe thats where the extra one ended up on the later models.
Old Oct 16, 2006 | 02:21 PM
is300wrx's Avatar
is300wrx
Originally Posted by is300wrx
that's why I asked....I only have one on each side and then I have the Y pipe, I have nothing..i guess i should be a happy camper
sorry, I made a typo. I have nothing after the Y pipe :-)
Old Oct 16, 2006 | 05:09 PM
Abaddon's Avatar
Abaddon
This has made me curious, now I have to gocrawl under my 04 cause i could have sworn i only saw 2 cats.
Old Oct 16, 2006 | 05:19 PM
Bob Jusnes's Avatar
Bob Jusnes
The first 2 are pretty high, right off the manifolds, the rear 2 are the most visible underneath.
