i really need some advice!!
Old Oct 15, 2006 | 03:40 PM
gansz4's Avatar
gansz4
Question i really need some advice!!
i own a 1989 ford f-150 two wheel drive. it has a 300 six, and a four speed trans...well yesterday i got in pushed the clutch pedal and and snap!! the bracket that holds the brake and clutch pedals broke out!!??? well today i ran down to the local salvage yard(not really it's like 50 miles) and wrenched a bracket that appears similar but i'm not for sure?? what is this bracket called, and how do i replace mine easier than the one i wrenched out????????? it wasn't real pretty!! i bought a haynes manual for what ever it was worth, i looked front to back and never found this part. any help would be appreciated!!!
Old Oct 15, 2006 | 07:59 PM
mississauga's Avatar
mississauga
Looks like the clutch and brake pedal share the same "bracket".That is what it is called in my 88 manual.From what I can see there is a shaft that goes through this bracket with bushings on it that the clutch and brake pedal share also. If you got the one out at the salvage yard it should be the same procedure for you vehicle and you have had a bit of practice. From the looks of the drawing there is no real easy way here. It is in a difficult location. Take your time.
Old Oct 15, 2006 | 08:10 PM
Steamir's Avatar
Steamir
There should be a part number on the bracket. You could go to your local Ford parts counter, they should have one.
Old Oct 16, 2006 | 03:36 PM
trgrhappy's Avatar
trgrhappy
My service manual gives a part number of 2L252 for the bracket. from the looks of the diagram the bracket is also part og the steering colum support.
Old Oct 17, 2006 | 04:24 PM
gansz4's Avatar
gansz4
thanks for the information, the pictures really help as far as knowing what parts are what!! i think this is still gonna take awhile!!
