Now what are you doing?!? I think it could be done, as long as the speed sensor from the 95 tranny will fit in your tranny. Then it's just a bunch of wiring issues to get the gauges connected, and fabrication to get the dash to bolt in. You might get lucky and find most of the wires are still color coded the same.
Yeah I'm hoping, seeing as there's a good chance I've got a local parts truck that should work. Mainly because I don't want to spend eternety wiring the 84 for my EFI 300-6.
Thats right, all the dash plugs would hook right up to the engine harness you took. I guess the speed sensor and bolting the dash in are your only real challenges.
