Offroad & 4x4
dana vs np205 devorced transfercase
Old Oct 15, 2006 | 09:25 AM
backwoodspuller's Avatar
backwoodspuller
hello i have been running a dana devorced transfercase in my pulling truck for 3 yrs now never had a proublem with it but i am rebuilding the truck now and going into mod class since i wount be able to afford a pro fab this year i am gonna run a devorced but i have a np 205 and a dana with one is stronger? i have hear the np205 is stronger but the dana hasnt let me down yet but i did step the truck up i was only running 33's now i am going with 35's
Old Oct 15, 2006 | 10:40 AM
fordraceboy's Avatar
fordraceboy
they are virtually identical in strength and design. i wouldn't hesiate to run a dana at all, oh wait- i did run one for 10 years with no problems and 38.5" boggers... it was the only thin on he truck that never failed. still hasn't and it's still running 38.5's... i say leave it in place until it dies..
Old Oct 15, 2006 | 06:00 PM
mark a.'s Avatar
mark a.
35's on a pulling truck ?
Old Oct 15, 2006 | 06:05 PM
backwoodspuller
yea 35 bf mt's on a pulling truck with 4:10's
Old Oct 15, 2006 | 06:13 PM
fishmanndotcom's Avatar
fishmanndotcom
i'm trying to think, what model t-case did dana provide to ford? the only one i can think of is the dana 20 found in early broncos
the 205's are STOUT, they are hands down tough as nails! i would not hesitate one second to run one, i dont care how much HP/TQ you are puttin out!
-cutts-
Old Oct 15, 2006 | 07:35 PM
FordPickup460's Avatar
FordPickup460
I think it was the Dana 21 or 24, I know Ford put one in the F100's that was a 1 speed transfer case, 4 High and 2 High. I think they used a Dana 2 speed transfer case also, but I cant remember the model number.
Old Oct 15, 2006 | 09:29 PM
backwoodspuller
i have a few dana devorced i think they are dana 20 but not 100% mine has 2hi 4hi 2low same as the 205 from what i can tell the dana's came in the late 60's till 71or 72 i have a 76 it came with a 205 and i have a 72 it came with a dana i havent ran a 205 but i hear good things about them but the dana like i said has been good to me so far i was running a dana 70 rear and snapped axels and yokes and spicers but the transfercase is still holding up but like i said i am in the middle of doing alot of changes so i want to strongest one i can get
Old Oct 15, 2006 | 10:07 PM
mark a.'s Avatar
mark a.
You wouldn't be competive with a set up like that around my neck of the woods in any class for that matter, 4.10's with 35's ? you'd better have a big/huge motor.
Old Oct 15, 2006 | 11:19 PM
fishmanndotcom
oo ok, yea, there were 2 versions (as mentioned by fordpickup)
Dana 21
Single-lever, single-speed
1969-76 F-100 1/2-ton trucks.
Dana 24
two-speed, divorce mounted
1969-73 F-250s.
since yours has a low range then its the Dana 24. unfortunately there is very little aftermarket to support the 24, even if it is a good case. this is what *I* would do. go ahead and continue to run the 24 but go ahead and start looking for a 205, get a good deal on one, then you'll have it just in case
-cutts-
Old Oct 16, 2006 | 09:18 AM
74fordtruck's Avatar
74fordtruck
Nah, they made a dana 20 as well, but I dont think they came in any fullsize rigs, about all you see in EB's and a lot of heeps. It's a 2-speed, and I guess they make a kit that's supposed to make it pretty stout too. I got one of those sitting in my garage. Still, np205's probably stronger.
Old Oct 26, 2006 | 12:35 PM
RMPC's Avatar
RMPC
Just a Note. Fishmanndotcom is right. The Dana/Spicer Model 21 was a single speed, divorced case used only on Ford F100's. Ok only as long as you had a big motor and or low gears. The Dana/Spicer Model 24 is a dovorced 2 speed, used in F250's from 1960 to the end of the 1972 model year when it was replaced by the NP205. Both are cast iron units. The Model 24 is pretty strong in construction...probably as good as a NP205 but the 1.98 ratio in low range isn't as low as what you can get in a NP205. Great for general off road use and hard pulls but doesnt have the deep low of a NP205 for things like serious rock crawling. I've had my 71 F250 4x4 since it was new...35yrs? and the only thing that I've replaced on it was the input shaft bearing and seal and shift shaft seals a couple of times.... I use it on the ranch in wyoming to feed round bales to cattle and have put it into some pretty tough situations over the years.
The Dana Model 20 that was mentioned here, was originally made for Jeep's. The Ford model of that series was used in the early broncos and was a cast iron 2 speed box with either a t shifter ( to '73) or a j pattern stick till end of production in '77.
Dana/ Spicer also made a model 23, which is identical to the model 24 internally but it had a right hand drop for GM trucks in the 60's as opposed to the left drop on Fords. It has been my experience that parts for the 21 and 24 are getting somewhat hard to find in your local parts store... why? not sure. There were millions of them made from 1959 to 1972 and occasionally you even see one on a 73 or 74 truck...
1972RedNeck
Apr 20, 2016 03:21 PM
applecarguy
30
Jul 20, 2014 12:38 AM
aidandj
Mar 23, 2014 10:14 PM
SilverHighboy
Jul 12, 2010 10:39 AM
bigoldblue
Apr 6, 2007 05:58 PM
