transmission question
Old Oct 15, 2006 | 07:09 AM
82F150Beast's Avatar
82F150Beast
My 82 F150 has the 300 i6 in it and the stock transmission. Going from 2nd to 3rd, there is a big loss of power like there should be another gear inbetween 2nd and 3rd. I have heard that was a normal complaint for those transmissions and was wondering if there is either anything that can be done to fix that or will I just need to replace it with another transmission? If I should replace it, what would be a good one to go with? Thanks much.
Old Oct 15, 2006 | 07:21 AM
srercrcr's Avatar
srercrcr
You don't say which transmission you have, but I'm guessing the M4OD. If that's the case, just stay in 2nd a while longer...and enjoy the fuel economy.
Old Oct 15, 2006 | 08:05 AM
82F150Beast
Sorry, yes its the M4OD. Ya I have been staying in 2nd for a little longer and it does help, but what about if I'm towing a boat or something, will that still be ok to stay in 2nd a bit longer?
Old Nov 24, 2006 | 12:09 PM
jacew's Avatar
jacew
I have the same complaint, I have an 81 with the 300-6 and this trans, i don't use my truck to haul anything much more than maybe some firewood occasionally, no towing, so i just want a 5 speed with a decent overdrive gear for highway driving, can anyone recommend a trans that will mate with the 300?
Old Nov 25, 2006 | 09:08 PM
clunker86's Avatar
clunker86
i would assume any tranny that will bolt to a 302 351w should work on the in line 6. i know from doing the research in the past the in line 6 did not use a conter balance on the fly wheel. the 6 was internally balnced. other than that there should be no differents.
