Aerostar Ford Aerostar
94 3.0 engine timing
Old Oct 14, 2006 | 06:43 PM
thefairlaneman's Avatar
thefairlaneman
Would someone refresh me on how to set the timing on my 1994 aerostar with a 3.0. I understand you have to disconnect the electronic advance first and this is where Im confused. thanks pals
Old Oct 14, 2006 | 06:53 PM
trk pny's Avatar
trk pny
I have an 89 3.0 and it is located approx right above the air intake tube and throttle. it is bunched up with a large run of electrical wires. it is a gray small plug. about 1/2 an inch square. I have heard it called spout connector.
Old Oct 14, 2006 | 08:24 PM
Bear River's Avatar
Bear River
Former ******
On a '94 it is between the TB and the EEC connector, along the main harness.
