fuel line ??
Old Oct 13, 2006 | 04:53 AM
ron's power stroke's Avatar
ron's power stroke
fuel line ??
i need to replace my fuel lins from the grey and blue lines by the drivers wheel up to the hpop..should i take the blue and grey line out of the system or does it need to stay?? how do i unhook these lines from the steel fuel lines?? thanks guy's
Old Oct 13, 2006 | 06:20 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
once you take the alternator off and the mounting bracket to the head/block, it's an easy deal. when i did my fuel system, i replaced them. too bad that i bent one off and cut it to get it out easier, or i would give it to you. there is a fuel line disconnect tool, its a collar that slides up into that connection, and a push opens the jaws inside and you can pull the line off. dont get a plastic one, get a nice metal one.
Old Oct 13, 2006 | 06:57 AM
Uzumati's Avatar
Uzumati
http://www.sjdiscounttools.com/vehic...ine-tools.html
Kris is the one you are refering to the 26 dollar one about half way down the page??
Old Oct 13, 2006 | 04:42 PM
ron's power stroke
thank you strokin_it7.3 are these lines air tight?? or should i remove them and replace with a new steel line? witch is the better option.. amiller93 put up a website with the tool thank you amiller93...witch one is it i need??
Old Oct 13, 2006 | 06:47 PM
PowerstrokeJunkie
no, that is to put them together, as far as it looks. however, a firm push and the line snaps into the connection easily. yes they are air tight, they seal extremely well under pressure, but not in a suction environment, that is why it is desired to remove them before the pump to prevent air entrainment. the tool you want is on the right side three rows above that part. the one that is $12.80. if i do remember correctly, the supply line is larger (3/8") than the return line (5/16") so you may need two different tools. hmm, you may be innterested in this tool KD TOOLS 3321 - FUEL LINE QUIK DISCONNECT TOOL 5/16 AND 3/8-- $10.24
if i were you, i would buy the lines direct from ford. pre-bent in the desired spots, and they have the QD connector on one side, and the flare fitting for the fuel filter housing on the other.
Old Oct 13, 2006 | 07:38 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Kris is right, metal ones are better but I get by with a plastic set that I bought at AZ for about $8. I just don't use it that often, and all you are doing is expanding a circular spring inside the coupling in order to release the connection.
Old Oct 13, 2006 | 07:52 PM
ron's power stroke
thanks alot for the tips guy's ill order from dealer then...and order me a tool..i want to do my trans lines too. any tips there? there a little rusty and im getting a true cool trans cooler a bts vb and dp tuner this week..i want to make sure every thing stays strong...little off topic but where do you guys hook your boost gauge into?? once again thanks alot for your help...
F-250 Super Duty
Apr 17, 2013 08:14 PM
Diesel cat
Dec 15, 2011 05:42 PM
RA31925
Jun 22, 2011 01:01 PM
jeremy2008
May 4, 2011 12:30 AM
etechnician
May 26, 2008 07:16 PM
