Front end swap?
Old Oct 13, 2006 | 12:28 AM
masterpickle's Avatar
masterpickle
Front end swap?
I have a 1994 F250 lifted 4 in on 35 in BFG's. It has the stock dana 44 TTB upfront. The front axle has everything wrong with it (bearings, tie rods ends, ect) would it be worth it to swap it out for a dana 60 or should I just deal with it and get it fixed. Also aproximatley how much would the swap cost? Thanks
Old Oct 13, 2006 | 09:03 AM
Kemicalburns's Avatar
Kemicalburns
your front axle is a Dana50, and upgrading to a D60 is always a good idea if you can afford it. ORU has a kit that would allow you to do this and be pretty much a bolt in. you will just need to find the axle and make sure its in tip top shape. figure $500-1000 for a front D60 for your year range. some have found them cheaper it just depends on the Yard really.
