hey does anyone know what the largest size tire is to fit on a 1995 Bronco/stock 15"wheels-without modifying the lift or anything-I am currently running 31X10.5r15 and am looking to go a little taller and wider.And also does anyone know how to remove the internal rear window switch
Search, Search, search... and try the Read First threads at the top of the forum. I know the tire answer is in there. There is a parts explosion of the tailgate guts in my gallery too.
i have 33x12.50 tires on mine and its stock . on the windowe switch pull the two dash trim pieces off the little ones that run horizontaly then take the lite switch **** off remove screws and tilt wheel all the way down if you have tilt . careful the plastic panel will break easy but you will have to force it a little block your tires and put shifter in nutural for more clearance . two screws on back side of pannel hold it in unscrew them and unplug the switch. i hope this helps its not as bad as i type or spell. oops i do have after market aluminum wheels.
I am looking to add some 33's to my truck as well... i was wondering what it looked like. But i wasnt aware that you could get 33's on stock suspension. I am assuming the tires rub a bit?
I looked at the gallery.. i couldnt really see what it looked like.
