Plug In
Old Oct 12, 2006 | 06:44 PM
THE KING's Avatar
THE KING
Plug In
Hey, For you North People, as you can tell the temps are comin downnn. I just got my first diesel truck, and it did not come with the right owners manual. So therefore i have NOOOO clue at what temp to plug it in at. Please help its gonna get cold tonight. Thanks
Old Oct 12, 2006 | 06:55 PM
PSNut's Avatar
PSNut
I would suggest plugging it in when it starts dropping into the 20's and below. Use a good timer and set it for about 2-3 hours before starting your truck.
On a side note, if everything with your GP system and your batteries are in tip top condition you should be able to start it without the block heater to well below zero.
Nut
Old Oct 12, 2006 | 06:57 PM
THE KING's Avatar
THE KING
OK thankyou
Old Oct 12, 2006 | 07:02 PM
fixnair's Avatar
fixnair
Smile
Congrats! At 112,000 miles it is just about broken in.
Old Oct 12, 2006 | 07:04 PM
Muktown's Avatar
Muktown
ya i have mine on a timer to come on 3 hours before school and if you use 5-40 synthetic oil it helps also. ive started mine at -5 without the block heater. the truck wasnt too happy about it but it just made some weird noises at first and then ran fine
Old Oct 12, 2006 | 07:09 PM
THE KING's Avatar
THE KING
Yup my dads is at 112000, Its in great shape except for the front end rattles around alot, I brought it into my school and we did an inspection, Its hard to do on a 3/4 truck lol, So Tomorrow its goin in the dealership for that problem and when your going 55, let off the gas all the way then put preasure back on the pedal the rear end has a little clunk that you can feel. My teacher said that it could be becuase of the milage but idk. Probably should get that looked at too, and also when he bought the truck he got a extended warranty so well see how that works out for him. Thankyou
Old Oct 12, 2006 | 07:11 PM
PSNut's Avatar
PSNut
I also recomend checking ,and if necessary, cleaning any oxidation off your three prong plug to the block heater cord as it gets very dirty and oxidized.
Some emery cloth rubbing to a nice shiny metal surface. This heater is 1000watts and pulls about 8amps nominal @ 115V AC. It CAN be a fire hazard...
trust me. The orange end at the engine block should be checked and cleaned too. Just remove the two prong retainer and pull the end out.
Hope this helps.
Nut
Old Oct 12, 2006 | 07:13 PM
THE KING's Avatar
THE KING
OK thanks i will do that tomorrow, When we bought the truck it acually took us both a long time to find that dang thing lol! But when we did the cover was off and there was mud in there, SO il clean that and the part that goes into the motor.
Old Oct 13, 2006 | 12:07 AM
kbeefy's Avatar
kbeefy
It shouldn't be to hard to find those rattles and clunks. Start by laying under it and have someone big put some weight in the drivers door sill, you should be able to find shock bushings, swaybay end links, and spring bushings that way. While your under the truck have someone saw the wheel back and forth just a little, enough to take the slack out of the steering. That should show you worn tierods and track bar. Last, jack one tire at a time up, put a crowbar or 2x4 under the tire and pry it up, watch the ball joints for play. While it's in the air give it a good shake, check for loose bearings.
Unfortunatly, balljoints, bearings, and endlinks are pretty common issues under there.
For you coast 'clunk', put the truck in neutral (make sure you don't squish yourself) and grab the rear driveline. Try to twist it both ways, check for movement between the driveline and yokes. Put pressure against the ends of the driveline and look for walking ujoints. Make sure the slip yoke is tight (push it up and down, try to twist it.
