2x4 to 4x4 conversion?
This is a crazy idea that a buddy and i have. We are wanting to turn a two wheel drive into a 4 wheel drive. Is this possable? What will it take to do such a thing? And if it is possable How much work will it take to do so? Thanks everybody.
Spike
There are companies out there that do 4x4 modifications for E-series vans, since you can't get them in 4WD stock. You might do some research there.
I suspect the best option is going to be having your dealer do the "upgrade" - trading in your 4x2, purchasing a new/used 4x4.
The sad truth is that it really isn't very feasible unless you have direct & free access to a wrecking/salvage yard(s) & have a fully functional shop. (And a huge amount of spare time.
) It is also relatively imperative that your project vehicle shares the same passenger compartment (cab/body...whatever you want to call it) & frame between the 4x2 & 4x4 models.If the floor of the cabs are different, you will likely have to do significant modifications to the floor pan in order to clear the transfer case & its shift linkages. This modification will require further modification within the passenger compartment, as seats & consoles will no longer bolt in like they had.
If the frames are different:
- The best choice would be to do a full frame swap. But, how often do you get a wrecked donor with an intact frame?!?
- The second alternative would be to find where the frames share the same dimensions, and then graft the front of the 4x4 frame onto the rear section of the 4x2 frame. This unfortunately creates a weak spot, as without major over-fabrication & reinforcing, the two frame halves will likely never be as strong as either of the two original frames.
- The last alternative is to custom fabricate the front end of the frame. Major applications of automotive suspension (forces, geometry, etc.) & fabrication knowledge will be needed to get this to work successfully.
It is not unheard of for the motors to be positioned slightly differently between a 4x4 & 4x2. This could create clearance issues once you start getting the front suspension, steering, driveshaft & axle put into place. Especially once you excercise the front axle through its full range of articulation movements--both sides fully compressed, both sides fully relaxed, one side fully compressed while the other is fully relaxed.
You'll also need to add in the transfer case support member, but this is probably the easiest step in the entire conversion process.
These are just the quick ones that I can think of off the top of my head....and that is, of course, assuming that you can get all of the various parts without going broke or taking out a second mortgage to do so.
Like everyone else has stated, trade the 4x2 in for a 4x4, or sell it out right & buy a 4x4.
On edit: Oh, and if it is a newer vehicle, you will likely need to get the primary & ABS computers reprogrammed to acknowledge that it is a 4x4. Unfortunately, most dealerships won't even touch this part of the conversion work. (Thanks to all of the litigation-happy Americans.)
this guy claims he can do it for you... only problem is he hasn't replied to my emails. i want a short bed 4x4... i know my truck and know its history. thats a big reason why i dont want to trade.
