stupid question
Old Oct 12, 2006 | 12:44 PM
5.0Torx's Avatar
5.0Torx
stupid question
hey all, how much oil, what kind of oil, and what oil filter do you guys use to change your 300?
Old Oct 12, 2006 | 12:47 PM
Silver Streak's Avatar
Silver Streak
6 quarts of Trop Artic 10W40 running through a Motorcraft FL1A.
Old Oct 12, 2006 | 01:20 PM
compaddict's Avatar
compaddict
Six quarts of Redline 10w-30 and Motorcraft filter!
Vince
Old Oct 12, 2006 | 07:08 PM
5.0Torx's Avatar
5.0Torx
thanks guys! gonna be changing her this weekend because i just got and suspect that the rpevious owners didnt take care of it very well...because, well, it has a frma oil filter. GAH! FL1A here i come!
Old Oct 12, 2006 | 07:19 PM
quicklook2's Avatar
quicklook2
do not use fram filters on your truck.
motorcraft filters are the way to go.
use good quality 10W30.
Old Oct 12, 2006 | 07:23 PM
Old Rust Bucket's Avatar
Old Rust Bucket
6 quarts of Bulk 10W-30. Power flow filter
Old Oct 12, 2006 | 08:14 PM
srercrcr's Avatar
srercrcr
Six quarts of Wallymart store brand 10W30 or 40, Fram usually.
170,000 miles, 23 years, excellent compression.....yea, those Fram filters suck, don't they? Wake up!
Old Oct 12, 2006 | 08:53 PM
Old Rust Bucket
Other than size is there realy that much difference between one oil filter and the next? Every one I've ever taken off has the same threaded hole in the middle and the same perforations around it.
Old Oct 12, 2006 | 08:57 PM
5.0Torx's Avatar
5.0Torx
ive heard fram glues a carbdoard base to the back of the can, and the filter element is glued to the cardboard base. motorcraft uses stamped steel all the way around, apparently. Thats just what ive heard. dont hurt me. its my damn truck anyway so the fram is coming off because i said so bitches! lol
Old Oct 12, 2006 | 09:39 PM
Silver Streak
Yea, they do. I used them for about the first 200k miles of my truck's life. Then the lifters started rattling for a few seconds after startup for no apparent reason. Turns out the reason is that the Fram filter either doesn't have an anti drain back valve or the one it has is a joke. Switched to the FL1A and it's never made a lifter noise again. 170k miles is nothing. When you really get some miles on it you can brag about your filter working great.
Old Oct 12, 2006 | 10:39 PM
beatupford's Avatar
beatupford
Fram sucks. 6 litres of 10W-30 mobile 1 with motorcraft filter. 5.4 litres i think.
Old Oct 12, 2006 | 11:01 PM
5.0Torx's Avatar
5.0Torx
yeah im definitely on the Fram Sucks bandwagon. why risk it, even if the hype is false? motorcraft is ford...i trust ford.
Old Oct 12, 2006 | 11:15 PM
Bandit-1's Avatar
Bandit-1
6 liters of shell 15w 40 deisel oil with a wix filter, 280,000 kilometers so far
Old Oct 13, 2006 | 09:25 AM
Red77F100's Avatar
Red77F100
Nobody uses Castrol GTX? Is this the oil equivalent to the "Fram sucks" argument?
Old Oct 13, 2006 | 01:51 PM
Old Rust Bucket
I have a question that seems to fit here. Why one brand of oil over the other? I realise different brands use different additives and the like but how much difference is there realy? The SAE sets standards for oil weights. So the weight of the oil is not going to vary from one brand to the next.
